Hall resistance and fine structre constant
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Constant Resistance
The discussion centers on the potential connection between Hall resistance and the fine structure constant, exploring both theoretical and conceptual aspects. Participants reference specific definitions and relationships from literature, including the quantized Hall resistance and its relation to fundamental physical constants.
  • Some participants assert that there is a connection between Hall resistance and the fine structure constant, referencing specific equations and constants.
  • One participant points out that the quantized Hall resistance is defined as h/e², while the fine structure constant α is defined as e²/(4πε₀ħc), suggesting a more complex relationship than a direct equivalence.
  • Another participant explains that the von Klitzing constant (quantized Hall resistance) is a resistance value that varies with units, contrasting it with the dimensionless fine structure constant.
  • There is mention of the need for additional factors such as the speed of light and ε₀ to relate the two constants, indicating that the relationship is not straightforward.
  • Participants discuss the Coulomb constant and its relation to the fine structure constant, with one participant clarifying notation and terminology used in physics.
  • One participant acknowledges a misunderstanding in their earlier statement about the relationship, emphasizing the importance of proportionality constants in the discussion.
Participants express differing views on the nature of the connection between Hall resistance and the fine structure constant. While some agree on the existence of a relationship, the specifics and implications of that relationship remain contested and unresolved.
Participants note that the definitions and relationships discussed depend on the choice of units and may involve additional factors that complicate direct comparisons. The discussion reflects a range of interpretations and understandings of the constants involved.
do they have any connection to each other (physically)?
im asking because i saw them mentioned in this webpage together:http://www.pha.jhu.edu/~qiuym/qhe/node6.html
Yes, they do.
The quantized Hall resistance goes like 1/[alpha]...
have you given a look at the page i have given.
it states that alpha=e^2/2h*c*epsilon_0 and the hall resistance is h/e^2, and 1/alpha=2h*c*epsilon_0/e^2 isn't h/e^2.
Hello loop, you are right that the q.Hall resistance is
h/e2. There is no question about that. It is how it is
defined in the NIST listings of the Fundamental Physical Constants.
A modern term for q. Hall is the "von Klitzing constant" which
metrologists (the experts in this area) want to call it because
the q. Hall effect, and this constant, were discovered by von Klitzing (1985 Nobel for this) so the normal nomenclature would be to call it after Klaus von Klitzing
http://physics.nist.gov/cgi-bin/cuu/Value?eqrk
or google with keywords [CODATA Klitzing]
In the NIST listing the definition of fine structure const alpha
is
a = e2/(4pi e0 hbar c)
That agrees exactly with what you said about 1/alpha.
So the two things are related---but not in a completely simple way. To get from one to the other you need some factors like c, the speed of light, and like epsilon-naught.
Formulas don't always convey physical insight but, for what its worth, here's the connection:
the quantum hall resistance = m0c/2a
maybe you would like to get an impression of the physical meaning of these things
alpha as you surely know is a pure number------not dependent on any system of units-----in whatever units it always comes out to be around 1/137.036...
On the other hand, the von Klitzing constant is a RESISTANCE so its numerical value depends on what units you use to measure resistance. If you use a big unit then it will have a small numerical value and so on.
So there could not be a really simple-minded connection between the two-----one is a pure constant number (a bit like pi itself!) and the other is a resistance quantity that varies numerically all over the place depending on choice of scale.
If you use metric units then the von Klitzing is IIRC some
25,800 ohms.
If you use natural units setting the values of hbar, c, G, and e all equal to one, then the value of alpha will still come out to be
1/137.036...
but the von Klitzing (quantum Hall) resistance will come out to
be 2 pi resistance units.
The von Klitzing is 2 pi times the natural Planck-style unit of resistance.
If you are familiar with the COULOMB constant that could give you a handle on alpha. The fine structure constant alpha is just the numerical value of the coulomb constant when it is expressed in the same Planck-style units.
Or what amounts to the same thing it is an index, in universal terms, of the strength of the attraction/repulsion between two unit charges----e.g. the repulsion between two electrons expressed in terms of the fundamental constants hbar and c.
is
hi marcus what does m0 stands for? (in mechanics it usually is the friction parameter i don't there is relation to the hall resistance phenomonon though).
Loop, human notation is influenced by custom, historical accidents and compromise and is sometimes unreasonably awkward
Are you familiar with (and comfortable with) the "coulomb constant" kCoulomb?
If you are sure about that one, the mu and epsilon can be explained easily.
As you very likely know, the Coulomb constant relates the force and distance between two point charges in the simplest imaginable way
F = kCoulomb multiplied by QQ'/R2
The force between the two charges is just equal to the two charges multiplied together and divided by the square of the separation and then multiplied by kCoulomb.
Well people have the Coulomb constant dressed in some other guises, for slick formula-writing.
kCoulomb = 1/4pi e0
e0 = 1/4pi kCoulomb
m0 = 4pi kCoulomb/c2
If people would just use kCoulomb , or if they pleased, 4pi kCoulomb , consistently they would not need these epsilon and mu thingees. In some timetested systems of units the epsilon and mu don't exist---no one bothers with them and it works out fine.
The old metric system Gaussian CGS was like that
But in the presentday metric system these epsilon and mu things are dignified with important-sounding names and fervently believed in by engineers---they are called "magnetic constant" and "electric constant"
by the NIST (National Inst. of Standards and Tech.)
MU used to be called "magnetic permeability of the vacuum" but that was just a little too silly for the NIST so they recently started calling it simply "magnetic constant"
And EPSILON used to be called the "electric permittivity of the vacuum" (another styrofoam term) but thankfully the NIST has had the decency to stop using that wording and now simply calls it "electric constant"
is
Apparantly my post wasn't entirely clear. Fortunately it was explained by marcus. I said "goes like" which is different from "is equal to". As marcus said, there are some proportionality constants to be included. PS: I DID look at the page you mentioned and some links there.
  • · Replies 42 ·
  • · Replies 36 ·
