When ice melts in a full glass of water, will the water overflow
  • Context: High School
  • Thread starter Thread starter bobsmith76
    Glass Ice Water
The discussion revolves around the question of whether the water level in a full glass will overflow, remain the same, or decrease when an ice cube melts. Participants explore the implications of buoyancy, density, and the physical principles involved in the melting of ice, touching on both theoretical and conceptual aspects.
  • One participant questions the reasoning behind the assertion that the water level remains the same, citing the density of ice and its buoyancy as factors that should influence the water level.
  • Another participant suggests that if the ice cube were to be denser than water, such as ice III, it would rest on the bottom and cause the water level to rise as it melts.
  • A participant introduces the idea that if the ice cube were chained to the base of the glass, the water level would lower as it melts, due to the change in density.
  • There is a discussion about the distinction between weight and mass, emphasizing that the amount of water displaced is equal to the weight of the ice cube when it is floating.
  • One participant notes that the melting of the ice cube will temporarily change the temperature of the water, which could affect its volume.
  • Another participant draws an analogy with a boat filled with ice floating in a lake, suggesting that the waterline remains unchanged as the ice melts.
  • Further questions are raised about the effects of cavities within the ice, such as air or molten water, on the water level during melting.
Participants express differing views on the effects of melting ice on water level, with some supporting the idea that the level remains the same while others propose scenarios where it could change. The discussion remains unresolved with multiple competing perspectives presented.
Some participants reference equations and principles related to buoyancy and density, but there are unresolved assumptions regarding the conditions under which these principles apply. The discussion also touches on the temporary effects of temperature changes on water volume, which are not fully explored.
This discussion may be of interest to individuals studying fluid dynamics, physics students exploring buoyancy and density concepts, or anyone curious about the implications of ice melting in water.
bobsmith76
If you have an ice cube in a full glass of water when the ice cube melts will the water flow over, be the same, or decrease? My book says the answer is stay the same, but I can't figure out why. Ice was less dense than water which is why is floats. Using this equation:
B = ρVg which when solved for V becomes
B/(ρg) = V
I would think the buoyancy would stay the same as the ice cube melts so the density ρ increases as the ice melts, so if you increase the denominator, the whole number decreases. So the water should decrease, not stay the same, unless the increase in density is compensated for by an increase in Buoyancy.
I shouldn't just hand this to you, I should walk you through it, but you're made some effort - and the diagram is right there...
An also interesting question would be why the melting of icebergs increase the level of oceans (I think it does, but I could be wrong).
Ok, I'm using this equation now
ρwaterAh = ρcubeVcube
As the volume decreases so too does the area and the height.
As already posted the same.
One somewhat novel exception is that that if you had a higher density form of ice, such as ice III (or higher stage of ice), it would be resting on the bottom of the glass instead of floating. In this case, as it melts, the density would decrease and the water level would rise.
fluidistic said:
An also interesting question would be why the melting of icebergs increase the level of oceans.
It's the melting of glaciers which are currently supported by land masses, not the oceans. As they melt, the water eventually runs off into the oceans.
Ok thanks rcgldr!
If the ice cube was chained to the base of the glass, then as it melts, it turns into denser water, so the water level will lower.
If the ice cube is buoyant, then the amount of water it displaces is equal to its own WEIGHT (not mass as someone else wrote); as it melts, the water level remains the same. The ice cube is less dense than water, so it will be "sticking up" above the water, and as it melts, it turns into denser water, occupying the same volume as the submerged portion of the ice cube.
If the ice cube had helium bubbles in it, then the helium would add even greater buoyancy, as it has negative weight against the atmosphere, and as the helium leaked out, the ice cube would WEIGH more (even though, without the helium bubbles, it has less mass), and so the water level will rise.
It is important to distinguish weight and mass. There's only a notion of "displacing" water because there's a force applied on the water to _prevent_ it from natural displacement (brownian motion). In this case, gravity and the contours of the glass. The water has a downward force keeping it from naturally flying out of the glass (gravity) - a weigh scale can measure this force. A buoyant object also applies a downward force - again measurable by a weigh scale. The water moves /upward/ in the presence of the buoyant object trying to go /downward/ because of the contours of the glass. If the glass were a pipe, you've just re-invented a pipe-cleaner and helped the liquid move further down the pipe. Because the glass has a strong bottom, the /bottom/ of the glass applies an upward force against the water. The water level then rises as the buoyant object submerges. If the only forces involved are gravity, then you'll get the same answer whether you use mass or weight, but if you introduce any other forces, the upward force on helium, or the downward force of a magnetic field tugging a buoyant object down, you'll get the incorrect answer using mass. For example, if you have an iron warship and a magnetic field pushing it downward, it will displace more water than an iron warship of equal mass without that additional downward force.
Your diagram is sublime :D
Would it be mischievous to point out that the melting of the ice cube will change the temperature of the water, and hence its volume?
Of course this effect will be temporary; eventually the whole thing returns to ambient temperature.
Think of a boat filled with ice that's floating in a lake. The ice in the boat melts, but the mass doesn't change, and the waterline stays the same.
There are some modifications to that question:
What happens to the water level during melting if the ice has...
a) ... a cavity with air inside?
b) ... a cavity with molten water inside?
c) ... a piece of lead inside?
No, that is already covered by the temperature causing the water to be ice. Think of the water and ice as a closed system and consider the average temperature of this system.
  • · Replies 52 ·
9K
  • · Replies 16 ·
  • · Replies 18 ·
55K
