What is the Cell Potential for Mg/Mg^2+ and Fe/Fe^2+ Electrodes?
  • Thread starter Thread starter MarcZZ
    Cell Potential
The discussion focuses on calculating the cell potential (ECell) for an electrochemical cell using Mg/Mg^2+ and Fe/Fe^2+ electrodes, with given standard reduction potentials of -0.45V for Fe and -2.37V for Mg. The correct formula to use is ECell = EReduction + EOxidation, where the oxidation potential of Mg is considered by changing its sign. The participants debate the correct answer, with one suggesting that the answer is B (1.92V) based on the reasoning of potential values. However, clarification is provided that the calculation involves understanding the distance between the half-cell potentials rather than simply changing signs. The final consensus indicates that the approach to determining ECell is crucial for arriving at the correct answer.
MarcZZ
Calculate the cell potential (ECell) of an electrochemical cell with Mg/Mg^2+, and Fe/Fe^2+ electrodes. [Mg^2+] and [Fe^2+] = 1.00 M.
Fe^2+(aq) + 2e^- --> Fe(s) = -0.45V
Mg^2+(aq) + 2e^- --> Mg(s) = -2.37 V
a) 1.90
b) 1.92
c) 1.94
d) 2.82
e) 2.80
I believe the answer is B as I believe because the Mg having a lower value of V will have it's sign changed to form a positive value (oxidation). Is this correct?
It is not about changing a sign. It is a about a distance between the half cell potentials - mark them on the number axis and it will be obvious.
Doesn't mean your answer is incorrect.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
