Finding spring constant by comparing to another spring
The discussion focuses on calculating the spring constant of a second spring based on the known spring constant of the first spring, which is 186 N/m. The objects attached to both springs oscillate with the same maximum velocity, but the amplitude of the first spring's motion is three times that of the second spring. The correct approach involves using the relationship between amplitude and spring constant in simple harmonic motion, leading to the conclusion that the spring constant of spring 2 is 20.6 N/m, although the initial calculation was incorrect due to a mix-up in the springs.
  • Understanding of simple harmonic motion
  • Knowledge of spring constants and Hooke's Law
  • Familiarity with oscillation amplitude and maximum velocity
  • Basic algebra for manipulating equations
  • Review the principles of Hooke's Law and its application in oscillatory motion
  • Study the relationship between amplitude and spring constant in simple harmonic motion
  • Learn how to derive spring constants from oscillation parameters
  • Explore examples of calculating spring constants in different physical scenarios
Students studying physics, particularly those focusing on mechanics and oscillations, as well as educators looking for practical examples of spring constant calculations.
rasputin66
Objects of equal mass are oscillating up and down in simple harmonic motion on two different vertical springs. The spring constant of spring 1 is 186 N/m. The motion of the object on spring 1 has 3 times the amplitude as the motion of the object on spring 2. The magnitude of the maximum velocity is the same in each case. Find the spring constant of spring 2.
My work...
Aw=Aw
A(sqrt of k/m) = A(sqrt k/m)
(sqrt of 186) = 3 (sqrt of k)
(sqrt of 186)/3 = (sqrt of k)
[(sqrt of 186)/3] ^2 = k
I got 20.6 but this is wrong, Please help!
You're on the right track. You just got the springs mixed up. Do it over more carefully.
OH MY GOD. What is wrong with me??
Thanks!
  • · Replies 17 ·
  • · Replies 17 ·
