Finding the pH of a buffered System
  • Thread starter Thread starter Glitche
    Ph System
The discussion centers on calculating the pH of a buffered system using TRIS and its conjugate acid TRISH+. Given concentrations are [TRIS] = 0.60M and [TRISH+] = 0.30M, with a dissociation constant Ka of 1.20 x 10^-6. The Henderson-Hasselbalch equation is highlighted as the appropriate method for solving the pH, expressed as pH = pKa + log([A-]/[HA]). Participants emphasize the importance of identifying the acid and conjugate base in the context of TRIS. Understanding this equation allows for straightforward calculation of the pH in buffered systems.
Glitche
1. A buffer system commonly used in the biochemistry lab uses a substance abbreviated TRIS, and it's conjugate acid TRISH+. A Buffer is prepared with [TRIS] = 0.60M and
[TRISH+]= 0.30M. What is the pH of this buffered System? The Ka for TRISH+ is 1.20 x 10^-6
[H+]=Ka [HA]/[A-] (Equation Attached)
3. I know the answer because I am studying off of a practice exam our professor gave to us, but I'd like to know how to solve it. The method I tried was [(1.20x10^-6)*(0.60/0.30)].
Thank you in advance!
Equation you listed is just a rearranged version of the dissociation constant. It can be modified even further, yielding so called Henderson-Hasselbalch equation:
pH = pK_a + \log \frac {[A^-]}{[HA]}
Once you have it it is just a plug and chug. You just have to understand what is the acid and what is the conjugate base in the case of TRIS.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
