How voltage amplification affects plasma flux density?
Voltage amplification can influence plasma flux density and magnetic fields, but maintaining constant power output leads to a decrease in current. For example, increasing voltage to 1000 volts reduces current to 1.5 mA, while 10,000 volts further decreases it to 1.5 microamperes. As plasma density is primarily dependent on current for a fixed gap, higher voltage with constant power results in lower plasma density. The ideal voltage-to-current ratio varies, but increasing voltage while keeping power constant negatively impacts plasma density. Understanding these dynamics is crucial for optimizing plasma applications.
CognitiveNet
Would a voltage amplification with the same power output increase plasma density and increase the magnetic field of the plasma, if the power output does not change?
In the case of a USB plasma globe with a current flow of 300mA through 5 volt, amounts to 1,5W.
CASE A:
Ofcourse this voltage has to be amplified in a transformer to at least 1000 volt, in that case the current would be nominal 1,5mA.
CASE B:
Now what if we amplified the voltage up to 10'000 volt, the current would be 1,5 micro ampere.
How would this affect the plasma?
Question 2:
What is the ideal voltage to current ratio for any given power?
The plasma density for a fixed gap will generally depend on the current, so increasing the volatge and keeping the power constant will produce a lower plasma density.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
