Measuring velocity in a pitot-static tube and manometer
The forum discussion focuses on calculating air velocity using a Pitot-static probe connected to a water manometer. Given a deflection of 7.3 cm and air density of 1.25 kg/m³, the derived air velocity is 33.8 m/s. The relationship between dynamic pressure and the height change in the manometer is confirmed, validating the use of Bernoulli's equation in this context. The discussion emphasizes that the pressure in the manometer corresponds to dynamic fluid pressure, allowing for accurate velocity measurements.
  • Understanding of Bernoulli's equation
  • Knowledge of fluid dynamics principles
  • Familiarity with manometer operation and measurement
  • Basic mathematical skills for solving equations
  • Study the application of Bernoulli's equation in various fluid dynamics scenarios
  • Learn about different types of manometers and their uses in measuring fluid pressure
  • Explore the effects of fluid density on velocity calculations in fluid mechanics
  • Investigate advanced topics in aerodynamics related to Pitot-static systems
Students in engineering or physics, professionals in fluid dynamics, and anyone involved in measuring air velocity using manometric techniques.
JJBladester
A Pitot-static probe connected to a water manometer is used to measure the velocity of air. If the deflection (the vertical distance between the fluid levels in the two arms) is 7.3 cm, determine the air velocity. Take the density of air to be 1.25 kg/m3.
http://composmentisconsulting.com/12-36.jpg
Pressure in a manometer = ρfluidgh
Dynamic pressure from the Bernoulli equation = \rho \frac{V^2}{2}
I reason that the height change in the water of the manometer is due only to the dynamic pressure entering the device. Therefore,
\rho_{air} \frac{V^2}{2}=\rho_{H_{2}o}gh
V=\sqrt{2\frac{\rho_{H_{2}O}}{\rho_{air}}gh}
V=\sqrt{2\left (\frac{1000}{1.25} \right )\left (9.81m/s^2 \right )(.073m)}=33.8m/s
I think I'm doing the math correctly. I just want to be sure my original assumption (that the pressure in the manometer = dynamic fluid pressure) is correct.
But, how can I relate this to the Bernoulli's equation?
Well, if you don't get any other replies, my take is that you can't. Bernoulli applies to a streamline only, and the pitot and static pressure sensors are not in the same streamline.
Other takes solicited!
Assume your manometer is water. If you look at the manometer on both ends, then you'll see that
P01 = P02
Ps1 + 1/2*rhowater*V12 + rhowater*g*h1 = Ps2 + 1/2*rhowater*V12 + rhowater*g*h2
assuming that the change in height is only dependent on the static pressure,
dPs,water = Ps2 - Ps1 = rhowater*g*(h1 - h2)
Now if you assume that the wind streamline starts at zero (1), and compare to the wind at the inlet to the manometer (2)
P01 = P02
Ps1 + 1/2*rhoair*V12 + rho*g*h1 = Ps2 + 1/2*rhoair*V12 + rho*g*h2
assume that the height is negligible
dPs,air = Ps2 - Ps1 = 1/2*rhoair*(V12 - V22)
Since the change is static pressure of the wind is directly affecting the change in static pressure at the manometer,
dPs,air = dPs,water
rhowater*g*(h1 - h2) = 1/2*rhoair*V22
If you measure the manometer's change in height, then you can find the wind velocity. So yes, your assumption is correct.
  • · Replies 26 ·
  • · Replies 17 ·
