Solve Math Problem: Time to Fill 425L Tank with Pipes
The discussion revolves around solving a math problem involving two pipes filling a 425-liter tank. The first pipe operates for 5 hours longer than the second, and if their roles were reversed, the first pipe would deliver half the water of the second. When both pipes are used together, they can fill the tank in 17 hours. Participants are encouraged to share their attempts and challenges to facilitate assistance. The goal is to determine how long the second pipe was open, with multiple-choice options provided.
sumitsawai
A tank of 425 litres capacity has been filled using two pipes, the first pipe having been opened 5 hrs longer than the
second.If the first pipe were to
open as long as the second and the second pipe was open as long as the first then the the first pipe would deliver half the
amount of water delivered by
the second pipe;if the two pipes were opened simultaneously,the tank would be filled up in 17 hours.How long was the second
pipe open?
a)10 hrs
b)12 hrs
c)15 hrs
d)18 hrs
Mathematics news on Phys.org
hi sumitsawai! welcome to pf! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Thats general algebra. Try to change the problem into values maybe helpful - that's what I do.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
