New Reply
Pulleys: Why would my calculated work output be higher than my work input?
Share Thread
Apr13-12, 12:51 PM   #1
The experiment in my Physics lab today was to determine the mechanical advantage and efficiency of various pulley systems. My calculated work output is higher than my work input, which is causing an abnormally high value for efficiency, and I am attempting to find the source of error. I have attached my data tables and a copy of the lab procedure.
2. Relevant equations
work output = (weight of load) * (height lifted)
work input = (force measured) * (distance moved)
3. The attempt at a solution
I guess it would be error in measurement, though I am unsure of how this could have happened.
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Apr13-12, 01:21 PM   #2
Recognitions:
Homework Helper Homework Help
Did you remember to include the mass of any pulleys that moved along with the load in the total load mass? (See step 7 instructions).
New Reply
Similar Threads for: Pulleys: Why would my calculated work output be higher than my work input?
Thread Forum Replies
work input/output in adiabatic process Introductory Physics Homework 0
Confusion about how to work out the uncertainty in my final calculated value! Introductory Physics Homework 1
When are work and heat calculated by differences in enthalpy or internal energy Advanced Physics Homework 1
Work input/output, efficient probelm, just need someone to check my work :) Introductory Physics Homework 1
Pulleys: How do they exactly work? Introductory Physics Homework 2
