Navigational Instruments Since Tsunami: Recalibration Needed?
  • Thread starter Thread starter Dayle Record
    Navigation
The discussion centers on whether navigational instruments need recalibration following changes to Earth's rotation and tilt due to a recent tsunami. While the tsunami did alter Earth's rotation by a few microseconds and shifted the North Pole slightly, the consensus is that these changes are negligible for most navigational purposes. For consumer gear, the margin of error remains well within acceptable limits, and military applications are likely to be adjusted without public disclosure. The International Earth Rotation Service monitors these variations, indicating that such shifts are common and manageable. Overall, the tsunami's impact on navigational accuracy is minimal and does not necessitate widespread recalibration.
Dayle Record
Since the Tsunami, changed the speed of our orbit, and set us off a bit on the planetary tilt; will every compass, and navigational instrument, in every vehicle, sub, satellite, plane, etc, have to be recalibrated? I think that a few millimeters, could become great, over thousands of miles. Or a few millimeters could be catastrophic, if there is a zero tolerance for error. What have you heard about this?
According to the TV shows I've seen on Discovery the rotation of the Earth was slowed by 3 microseconds, the same amount occurs every 100 days because of the effect the moon has on the earth. The north pole shifted something like an inch or two and that would be the largest manifestation of the inclination shift.
For consumer gear, this is well below the margin of error. For the military, I doubt they would tell anyone if it wasn't. :smile:
Cliff
You're slightly inaccurate. The Tsunami changed the speed of the Earth's rotation, not the speed of our orbit.
The Earth's rotation rate and the orientation of its axis changes constantly. Even tiny errors can build up over time, which is why both are analyzed and recorded by the International Earth Rotation Service (the US Naval Observatory cooperates with the IERS as kind of the US component of this organization).
Actually, a few milimeters, over thousands of miles, becomes negligible. The crust shift at the fault line may have been 60 feet (not sure if that was permanent), but hundreds of miles away, its much smaller. Thousands of miles away, its microscopic.
The location of the poles vary throughout the year... by a few inches.
And the rotation rate changes by a few tens of milliseconds throughout the year.
So, no biggie... this tsunami is not a significantly huge terrestrial event (despite what the media is saying... and the chicken-littles are believing).
See here for more info on pole location movement.
Cheers...
Thanks for any and all answers, and corrections.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
