Do Cable Trays in Sydney Car Parks Require Individual Earthing?
In Sydney, the earthing requirements for cable trays in car parks are not universally defined and depend on local electrical codes. The discussion highlights differing opinions on whether each 3-meter length of galvanized cable tray should be individually earthed or if one earth connection per run end suffices. It emphasizes the importance of consulting local regulations, as practices vary globally, with references to IEC standards and NEMA guidelines from the U.S. Additionally, the bonding of metallic trays to the building's metal frame may be necessary for effective grounding. Ultimately, adherence to local codes is crucial for compliance and safety.
Futsal1st
I am looking at a building with a car park in Sydney. Electrical circuits are run on perforated cable trays at high level.
I understand that the trays require earthing, however, I'm trying to determine the extent.
The trays are made from galvanized sheet and come in 3 meter lengths and are butted to each other. Two short straps (around 100mm long), one on each side, are used to join the lengths together. 10mm bolts and nuts are used for the connection.
Should the trays be individually earthed or only one at each run end or some thing in between? I have been told by one contractor that one Earth per tray is adequate. I've been told by an electrical engineer that each 3m length of tray should be individually earthed.
Advice please ..
Thaks
There are hundreds of "standard" earthing practices around the world. There is no universal answer. You must consult your local electrical codes. It is not only wise, but probably legally mandated that you do so.
Likes berkeman
In my opinion, Australia use IEC standards for electrical installations.
IEC 61537 Annex C Protective Earth [PE] function.
But -as far as I know- no Annex C is detailed still. It is "under consideration".
In U.S.A. NEMA VE 2-2013
3.8.1 Cable Tray Used as an Equipment Ground Conductor (EGC)
3.9 BONDING TO THE METAL FRAME OF THE BUILDING AND EARTH
Metallic cable trays are permitted to be bonded to the metal frame of the building and Earth for signal grounding (“noise” prevention). This may be desirable if the cable tray system is not inherently bonded (connected) to the metal frame of the building and Earth through metallic support systems.
NEMA VE-2 2001 Edition recommended all 60 feet .From 2006 there is not any recommendation of the bonding interval.
The grounding bonding methods are stated in NEC[2017] Art.250.8
250.8 Connection of Grounding and Bonding Equipment. (A) Permitted Methods.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
