| New Reply |
Thermo! Intensive properties and const. vol. compression |
Share Thread | Thread Tools |
| Apr27-12, 06:18 AM | #1 |
Hello. I need help with some thermo basics.
I can't understand the concept of constant volume compression/expansion. Please help me understand how it occurs. Also, I am not clear on how pressure is an intensive property. To my understanding it IS a quantity dependent on system size (eg: compression) or mass in the system (more mass = more force). Please help me with where I might be getting it wrong. Similarly with temperature. |
| Apr27-12, 08:39 PM | #2 |
Recognitions:
Compression here means, literally, increasing pressure. If you heat a gas at constant volume the pressure increases.
The use of the word "expansion" in that context does strike me as wrong, though. Decompression would be better. If I have a container of gas at uniform pressure P, the pressure is the same within each region. If I partition it into separate regions, each will inherit the same pressure. Suppose it's a rectangular box. The total force on a wall of area A will be A.P. So yes, scaling up means more force, but not more pressure. |
| Apr27-12, 10:54 PM | #3 |
Thanks a lot. My confusion stemmed from my understanding of the word compression as a reduction in volume.
One final question: Are the definitions of intensive and extensive properties valid only for a fixed system state? As in, I understood what you are saying about the container and the uniform pressure within, but I was confused thinking about the changes to P and T when the size is changed by say, compression, using a piston. But then, that is work being performed on the system, changing its state. Thanks again. :) |
| Apr27-12, 11:34 PM | #4 |
Recognitions:
Not sure what you mean by this next question. If the system state changes then the properties can change.
See if http://en.wikipedia.org/wiki/Intensi...ive_properties helps. |
| Apr28-12, 01:18 PM | #5 |
Recognitions:
Compression of a quantity of gas (volume reduction) occurs if the external pressure exceeds the internal pressure of the gas. This can occur either because the temperature of the gas decreases or the external pressure applied to the gas increases. Expansion is the opposite. Expansion occurs if the internal pressure exceeds the external pressure applied to the gas. This can occur because the temperature of the gas increases or the external pressure decreases. If the volume is fixed, changes in pressure or temperature do not result in expansion or compression. AM |
| Apr28-12, 04:29 PM | #6 |
Recognitions:
| Apr28-12, 11:21 PM | #7 |
Recognitions:
AM |
| Apr29-12, 06:28 PM | #8 |
Recognitions:
I see the same usage at http://www.engineeringtoolbox.com/co...es-d_605.html:
"If a compression or expansion takes place under constant volume conditions". Compression at constant volume I can justify, but expansion? |
| Apr29-12, 11:44 PM | #9 |
Recognitions:
The author is clearly describing a reversible adiabatic expansion or compression. There is no change in entropy because Q = 0. AM |
| New Reply |
| Thread Tools | |
Similar Threads for: Thermo! Intensive properties and const. vol. compression
| Confusion over intensive properties (Thermo) | Classical Physics | 5 | ||
| Isothermal compression vs thermally isolated compression | Introductory Physics Homework | 2 | ||
| Thermo residual properties | Biology, Chemistry & Other Homework | 0 | ||
| Intensive Variables | Introductory Physics Homework | 2 | ||
| intensive vs extensive | Introductory Physics Homework | 1 | ||
