| New Reply |
Generate a uniform random vector |
Share Thread | Thread Tools |
| May17-12, 03:49 AM | #1 |
Hi all, I'm trying to generate uniform random vectors with n dimensions.
To be more precise, each of the elements of the vector must be a uniform distributed variable in [0,1] The constraint is that the sum of the elements of the vector must be 1. I tried different solutions for over a week but i can't get it working. Can you help me, please? |
| May17-12, 04:16 AM | #2 |
There are many ways to do this, but one that I think is simple an intuitive is to generate N independent U(0,1) realizations and then normalize all elements by dividing by the total sum of all elements. In terms of generation, the actual mechanisms can be complicated but you can use anything from R to QBASIC to generate a random number from U(0,1). You can also use a random number table which is just a printed table of random numbers. Also another good source of random numbers is http://www.random.org In R (which you can download for free) the command for generating a realization from a uniform distribution is runif() and you can type help(runif) in R to give the command line arguments. |
| May17-12, 04:42 AM | #3 |
| May17-12, 04:46 AM | #4 |
Generate a uniform random vectorYou can use R like a console: you type in one command and it will spit out the output. You type one command at a time and you can store results in variables. You don't need to declare variables like you do in C or C++ and it's a lot easier than using C or C++. |
| May17-12, 07:20 AM | #5 |
Recognitions:
We can't guess what you really want to do here, but think about the case where N = 1 and it should be obvious that what you desribed in your OP is impossible.
If there is a constraint involving N variables, you can only make N-1 indepedent choices. You probably need to think what that means in terms of the problem you want to solve, before you get into the details of writing code. |
| May17-12, 07:37 AM | #6 |
Generate v[0] as uniform[0,1] Calculate v[1] as 1-v[0] Result: 2 uniform variables (not independent but uniform) If you plot the frequencies of the two variables, the plots are "flat". I mean each of the two variables is uniformly distributed. Obviously v[1] is uniform by definition. Then v[1] is uniform too but "mirrored" with respect to 0.5. I think that this could be valid with more than 2 variables. I thought that someone could know some well known mathemagical formula to generate this kind of vectors ;-) |
| May17-12, 11:45 AM | #7 |
Recognitions:
| May17-12, 12:02 PM | #8 |
| May17-12, 03:24 PM | #9 |
Recognitions:
In order to get a unit N dimensional unit vector, uniform on the surface of an N sphere, you need to be careful. The suggestion that you take N independent uniformly distributed between -1 and 1 is incorrect since the distribution will not be the same as uniform on the N sphere. To illustrate let N = 2, then you would be picking points uniform on a square so that directions along the diagonals would be preferred.
To avoid this use a rejection technique, and keep vectors only if the original length is < 1. The main problem with this approach is that it is inefficient for higher dimensions. Alternatively one could convert to the N dimensional analog of spherical coordinates and choose angles uniform in the appropriate domain. |
| May18-12, 08:24 AM | #10 |
| May18-12, 09:15 AM | #11 |
Recognitions:
I don't know if this is relevant to the goal of the original post, but in post #4 of the thread, http://physicsforums.com/showthread.php?t=587264, the member Petawa gives a link to a paper that deals with selecting a random subspace in N dimensions. "Some Remarks On A Lemma Of Ran Raz" by Milman and Wagner.
| May18-12, 11:00 AM | #12 |
My original idea was to find a distribution (not uniform) to generate these angles such that the result of sin and cos would be uniform. I don't know if it is possible or not |
| May18-12, 11:08 AM | #13 |
| May18-12, 02:41 PM | #14 |
Recognitions:
If the sum of the elements must be 1, the subspace isn't a sphere.
If N = 2 it is a straight line joining (1,0) and (0,1), which gives a simple interpretation of why post #6 "works" for that special case. If N = 3 it is the surface of an equilateral triangle with vertices (1,0,0), (0,1,0) and (0,0,1). Maybe you really want a uniform distribution of points on the area of the triangle? If so, it's fairly clear that the x y and z coordinate are not an easy way to measure that. It would probably be better to choose the random variables using two parameters that describe the surface, then transform the point back to (x,y,z). For N = 4 the points fill the volume of an "equilateral" tetrahedron embedded in 4-D space, and similarly for higher values of N. |
| May18-12, 03:04 PM | #15 |
I explain better the problem: This vector is the input of an heuristic optimization algorithm, the random restarts are useful to find the global maximum. I want to restart in very random points (uniformly). So, I think that sampling the hyper-tetrahedron uniformly could be the best solution. Do you agree? |
| May18-12, 04:21 PM | #16 |
Recognitions:
| May18-12, 04:34 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Generate a uniform random vector
| Can the mind generate random numbers? | General Discussion | 61 | ||
| Generate random numbers by hand? | General Math | 5 | ||
| How to get Excel to generate any random number besides x? | Math & Science Software | 6 | ||
| MATLAB code to Generate Uniform Random Variable | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Random Unit Vector From a uniform Distribution | Set Theory, Logic, Probability, Statistics | 2 | ||
