Sallen-Key Filter: Understanding LPF & Bootstrap Capacitor
  • Thread starter Thread starter likephysics
    Filter
The discussion revolves around understanding the Sallen-Key low-pass filter (LPF) configuration, specifically focusing on the role of feedback through a capacitor and the concept of bootstrapping. Participants explore the theoretical and practical aspects of the filter's design and operation.
  • Some participants express confusion about the feedback path from the op-amp output to input through a capacitor, questioning whether it is a bootstrap capacitor and seeking clarification on the term "bootstrap."
  • One participant notes that the Sallen-Key configuration is not intended for amplification but rather to achieve a second-order system that performs a filtering function, emphasizing the importance of the capacitor for the desired transfer function.
  • Another participant describes the complexity of the filter and the balance required in feedback values, mentioning that excessive feedback can lead to oscillation.
  • There are corrections regarding the labeling of components (Z3 and Z4) and discussions about the implications of connecting these components to ground versus the op-amp output, with some arguing that positive feedback is necessary for achieving resonance.
  • Participants suggest solving the circuit mathematically to understand its behavior, indicating that applying Kirchhoff's Current Law (KCL) and voltage-divider principles could clarify the transfer function.
  • Some participants express uncertainty about the meaning of "bootstrap" and whether it equates to positive feedback.
Participants do not reach a consensus on the understanding of bootstrapping or the implications of feedback in the Sallen-Key filter. Multiple competing views and interpretations remain, particularly regarding the necessity and effects of positive feedback in the circuit.
Limitations include potential misunderstandings of terminology (e.g., "bootstrap") and the complexity of the mathematical analysis required to fully grasp the circuit's behavior. There are unresolved questions about the specific configurations of components and their impact on filter performance.
likephysics
Trying to understand how sallen key LPF works. But I can't figure out why there is a feedback path from op amp output to input thru a capacitor. Is it a bootstrap cap. What exactly is bootstrap?
The Sallen and Key configuration is not for creating an amplifier. It's a particular arrangement to realize the second order system which performs the general filter function. Without that capacitor, the block would not have the desired transfer function. As frequency goes up, there is more feedback through the capacitor, thereby reducing the gain with increasing frequency: a filter characteristic.
likephysics said:
I read the wiki before posting. Doesn't say much about bootstrapping.
Instead of connecting Z4 to ground, it's connected to opamp output. How would one come up with this idea?
I find these kind of filter is quite complicate to be explained in simple terms. You notice the cap feedback from output to the junction that eventually driving the +ve input. It is some sort of positive feedback. Obvious it work with the RC low pass section to prevent the possible oscillation due to positive feedback. It is a balance dance of values. I had tried to adjust the amount of feedback from the output of the opamp and easily get into oscillation if just a little too much feedback.
Bottom line, it is not going to be apparent, and that's the reason a lot of people ( ME!) just use the circuit and concentrate on adjust the "d" of the circuit to get the right characteristics. If you really insist on understanding everything, go through the math step by step and see what happen.
yungman said:
i corrected "Z4" to "Z3" as indicated in http://en.wikipedia.org/wiki/Sallen–Key_topology#Generic_Sallen.E2.80.93Key_topology
Instead of connecting Z3 to ground, it's connected to opamp output. How would one come up with this idea?
Z3 was connected to ground like Z4, there would be no "positive feedback" (is that what you mean by "bootstrapping"?). without positive feedback, if the circuit were to be used as a LPF (and Z3 and Z4 were capacitors), you could not get a high enough Q to have any resonance.
i way to understand the circuit is to solve it. represent the non-inverting op-amp circuit as an ideal voltage-controlled voltage source. apply KCL to the node that Z1, Z2, and Z3 are connected to. apply a voltage-divider on the node with Z2 and Z4 and the + terminal of the op-amp (which becomes the reference voltage for the voltage-controlled voltage sour). two equations, two unknowns and you can see how the transfer function comes out.
if you want, do it again, but with Z3 connected to ground and see what you get (not any different than a passive circuit and it will have a limit to the Q.
What do you mean by "i corrected Z4 to Z3"?
Z4 is connected to ground and it is not connected to the op-amp output. but the question makes perfect sense if "Z4" is changed to "Z3".
but i still don't know what like means by "bootstrap". i am presuming it means positive feedback.
sorry folks, but i didn't proofread this. some sentences were not complete. it's too late to edit it, so i am quoting it with corrections:
rbj said:
if Z3 was connected to ground like Z4, there would be no "positive feedback" (is that what you mean by "bootstrapping"?). when this circuit is used as a LPF (and Z3 and Z4 were capacitors), you could not get a high enough Q to have any resonance, without positive feedback.
a way to understand the circuit is just to solve it. represent the non-inverting op-amp circuit as an ideal voltage-controlled voltage source. apply KCL to the node that Z1, Z2, and Z3 are connected to. apply a voltage-divider on the node with Z2 and Z4 and the + terminal of the op-amp (which becomes the reference voltage for the voltage-controlled voltage sour). two equations, two unknowns and you can see how the transfer function comes out.
if you want, solve it again, but with Z3 connected to ground and see what you get (not any different than a passive circuit and it will have a limit to the Q.
