How to Calculate Torque of a Leaning Rigid Body
The discussion focuses on calculating the torque of a leaning rigid body, specifically a ladder against a wall. The key point is that torque is calculated using the distance to the center of mass, which is typically halfway up the ladder, due to gravity acting at that point. The user initially struggles with integrating to find torque but realizes that their setup was incorrect, particularly in identifying the mass elements. The correct approach involves using a Riemann sum to account for the distribution of mass along the ladder, leading to the conclusion that the torque calculation aligns with the center of mass concept. Ultimately, the user gains clarity on the integration process and the significance of recognizing the center of mass in torque calculations.
Bennigan88
So this is a conceptual question, it's not a direct homework question, but it does involve how to do a kind of calculation. I hope this isn't the wrong place to post a nonspecific question like this. In the case of a board/stick/ladder leaning against a wall, about an axis O at the bottom of the object where it is in contact with the ground, why is the distance used to determine torque (which is Force x Distance x sin θ) halfway up the ladder? Ladder is 15m long in my example.
I tried to use integration to calculate the torque, and this is what I ended up with:
<br /> \tau = mg \times x \times \sin\theta = mgsin\theta \cdot x \\<br /> <br /> d\tau = mg \sin\theta \cdot dx \\<br /> <br /> \int d\tau = \int mgsin\theta dx \\<br /> <br /> \int d\tau = mg \sin\theta \int dx \\ = mg \sin\theta \int_0^{15} dx \\<br /> <br /> = mgsin\theta \cdot x |_0^{15} \\<br /> <br /> = 15 \cdot mg \sin\theta
So why is the scalar for distance 1/2 of the length rather than the entire length like my calculations? What am I missing? Thanks for any insight.
! The mass also changes, so I think I need a differential mass element... more thinking required :/
Because gravity acts at the center of mass.
Or can I use a Riemann sum to calculate the torque? Assume the ladder is divided up into n pieces, and the mass of each piece is its linear density λ times the change in distance.
<br /> \tau = x \cdot F \cdot \sin\theta \\<br /> F = m \cdot g \\<br /> m = \lambda \Delta x \\<br /> \tau_i = x_i \cdot \lambda \Delta x \cdot g \cdot \sin\theta = \lambda g \sin\theta \cdot x_i \cdot \Delta x \\<br /> \sum_i^n \lambda g \sin\theta \cdot x_i \cdot \Delta x \\<br /> \lim_{n\to\infty}\sum_i^n \lambda g \sin\theta \cdot x_i \cdot \Delta x = \int_0^{15} \lambda g \sin\theta x dx\\<br /> = \lambda g \sin\theta \cdot \int_0^{15} x dx = \lambda g \sin\theta \cdot \left[ \dfrac{1}{2}x^2 \right]_0^{15}<br />
I don't see this moving towards a validation of the torque being calculated at the half-way point with mg acting on the center of gravity... can anyone nudge me in the right direction?
I am aware of that, but shouldn't I end up finding the same torque using integration?
Well yes - and the integrated part will amount to finding the center of mass.
So your question amounts to: "how come I keep blowing the math?"
Bennigan88 said:
<br /> \tau = mg \times x \times sin ^\theta = mgsin\theta \cdot x \\<br /> <br /> d\tau = mgsin\theta \cdot dx \\<br />
Not sure what the first equation is saying, but the second is wrong. The RHS is the mass of the element dx multiplied by g sin(θ). The distance is x sin(θ):
<br /> d\tau = mgxsin\theta \cdot dx \\<br />
* Actually I think you got it right in the reiman sum - the first integral was poorly set up which is why it didn't work.
Finish the calculation.
<br /> g\lambda\sin(\theta)\int_0^L x.dx = g\lambda\sin(\theta)\cdot \frac{1}{2}x^2 \bigg |_0^L = \frac{g\lambda L^2}{2} \sin(\theta)<br />
... which is what you want - because λL = m, the mass of the ladder.In the first derivation, you misidentified the elements - it should have gone from \tau = mgx\sin(\theta) to d\tau = gx\sin(\theta)\cdot dm.
In the second derivation you lost confidence just before the payoff :)
You're right! I'm thrilled! I need to get better at recognizing things in the answers. This isn't the first time I've gotten something more or less right but didn't see it because I didn't make the connection. Thanks for seeing it through with me!:biggrin: Generalizing the 15 to L was I think the coup de grace that I was missing.
