Electrically secure connection of battery tabs
  • Thread starter Thread starter Andy Haard
    Battery Connection
The discussion focuses on connecting prismatic LiFePo4 pouch cells into a battery pack, specifically addressing concerns about the long-term reliability of connections made with G10/FR4 isolators and M8 threaded rods. There is a consensus that welding is the preferred method for securing battery tabs, but alternatives like bar clamps may be considered if welding is impractical. Participants emphasize the importance of preventing moisture exposure to the contacts and advise against using substances like Vaseline, recommending instead professional moisture sealants. Cleaning the battery tabs with appropriate solvents is also highlighted as crucial before making connections. Overall, ensuring secure and moisture-resistant connections is critical for the performance and safety of the battery pack.
Andy Haard
Hi
I'm working on a way of connecting prismatic LiFePo4 pouch cells into a battery pack.
I'll probably use G10/FR4 for the isolators, as suggested by MQuack in the Mechanical section of this forum, see this animation (the green parts are the FR4 isolators):http://www.youtube.com/watch?v=mh9fptEnvcM The animation only shows a portion of the complete pack that will be made up of 152 pouch cells, 2p76s
My concern though is if pressing the isolators together using 3 M8 threaded rods will create enough pressure to secure the connections between the battery tabs in the long run in an automotive environment...?
Any taughts on that?
I would think you would want to separate the contacts from any source of moisture such as and ambient air. The DIY way of doing this is to gob Vaseline on the contacts.
If you are trying to make an electric car battery, there are other considerations as well (which you may be aware of): thermal monitoring, fusing and service disconnect.
Battery tabs of pouch cells are normally welded together to bus bars or zipper fuses. Any other method such as clamping or some type of crimp has more resistance than what's allowable for most applications. And BTW, the battery tabs are the hottest part of the battery pack due to higher current densities and ohmic losses.
If welding isn't an option (as its very difficult to get right) you may want to try bar clamps onto a bus instead.
And don't ever ever ever put anything in between the battery tabs such a vaseline or what ever else. Thats just a recipe for disaster. The only thing that would be OK is something like electrical tape or a material that's designed for electrical applications.
Thanks Topher, I certainly won't put anything between the tabs, other than alcohol to make sure there absolutely clean before pressing them together.
Welding isn't an option, as you say; it's very difficult to get it right and I like the possibility to be able to replace a bad cell without to much difficulty.
fyi, the load will never be more then 150 amps.
I'm also considering using isolators like this:
The pointy sharp screws will press through the battery tabs.
With this many amps going through non-welded contacts you probably should consider doing something to mitigate moisture. Alcohol often contains water. You may be better off cleaning with something like MicroCare Pro-clean. There are products out there that provide a more professional moisture seal than Vaseline such as 3M Scotch 1600 anti-corrosion spray.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
