DO-160 Pin Injection waveform generation
Guidance is requested on building equipment for generating specific waveforms as outlined in DO-160 section 22. The original poster has found that searching online yields a plethora of information. However, they are seeking more targeted learning materials or resources. Participants in the discussion may provide insights or direct links to useful references. The conversation emphasizes the need for clarity and specific guidance in waveform generation related to DO-160 standards.
hemant03
Hi,
Can I get some learning material or guidance on how to build equipment for generating specific waveforms of DO-160 section 22?
Thanks
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
