Thread Closed
Pump
Share Thread Thread Tools
Feb9-05, 03:47 AM   #1
Pump
Air pump is pumping out a gas from a vessel (vessel's volume is V).
After each cycle i it pumps out dV.
Gas is ideal. T=Const.
After how much cycles pressure P will decrease k times?
Here is my work.
PV = nRT
Initially n=n(0)
After each cycle n decreases (1-dV/V) times.
So, after x cycles n(x)=n(0)(1-dV/V)^x
k=p(0)/p(x)=n(0)/n(x)
n(x)/n(0)=(1-dV/V)^x
So x =ln(1/k)/ln(1-dV/V)
But the answer is x=ln(k)/ln(1+dV/V)
As I understand, they assume that after each cycle n decreases 1/(1+dV/V) times. In this way i really receive x=ln(k)/ln(1+dV/V)
I don't understand it. Help me please.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb9-05, 01:05 PM   #2
Has anybody any ideas?
Feb9-05, 01:36 PM   #3
They have done some mathematics with x =ln(1/k)/ln(1-dV/V) to arrive at a more nice looking answer.
x= -ln (k) / ln (1- dV/V)
= ln (k) / ln [(1-dV/V)] ^-1
now, [(1-dV/V)] ^-1 = 1 + dV/V (approximately)
so, x = ln (k) / ln [(1+dV/V)
Feb9-05, 02:05 PM   #4
Pump
Each cycle corresponds to a T=const. process. (in another version of this problem the pumping process is very fast and a the transformation would correspond to an adiabatic process - all you have to do is to add the exponent [tex]\gamma[/tex] to the equations below). After the first cycle the air volume increases from V to V+dV and the pressure decreases at [tex]p_1[/tex]. You have
[tex]p_0\cdot V=p_1\cdot (V+dV)[/tex]
After the first cycle, the pump takes out the air from dV, and you get again
[tex]p_1=p_0 \frac{V}{V+dv}[/tex]
In the second cycle,
[tex]p_1\cdot V=p_2\cdot (V+dV)[/tex]
and
[tex]p_2=p_1 \frac{V}{V+dv}=p_0 \frac{V^2}{(V+dv)^2}[/tex]
and so on.....
[tex]p_n=p_{n-1} \frac{V}{V+dv}=p_0 \frac{V^n}{(V+dv)^n}[/tex]
Thread Closed
Thread Tools
Similar Threads for: Pump
Thread Forum Replies
Heat Pump Introductory Physics Homework 6
Power of a pump Introductory Physics Homework 2
the perfect pump General Discussion 1
Difference between a fan and a pump? Mechanical Engineering 16
micro pump :S General Engineering 5
