| New Reply |
Centroid of a C-Shape |
Share Thread | Thread Tools |
| Sep11-12, 12:36 AM | #1 |
http://prntscr.com/fcbm8 Find the centroid - All dimensions are in mm 2. Relevant equations xbar = (A1X1+A2X2) / (A1+A2) Similarly for Ybar I assume 3. The attempt at a solution I got the y co-ordinate to be 20.428mm, and would assume that the x coordinate would be 5mm. Is this right? |
| Sep11-12, 02:34 AM | #2 |
You can divide the shape into three rectangular parts several different ways but I used two vertical lines in the obvious places. I assumed the origin is in the bottom left corner.
xbar = (A1X1+A2X2+A3X3) / (A1+A2+A3) = (700*5 + 800*30 +400*30) / (700+800+400) = 20.789 ybar = (A1Y1+A2Y2+A3Y3) / (A1+A2+A3) = (700*35 + 800*10 + 400*65) / (700+800+400) = 30.789 Best show your working as my answer is quite different. |
| Sep11-12, 02:54 AM | #3 |
This is what confused me, does this mean the centroid is not on the shape itself?
| Sep11-12, 03:49 AM | #4 |
In this case yes. Where would the centroid of a doughnut be?
| Sep11-12, 06:35 AM | #5 |
| Sep12-12, 04:24 AM | #6 |
I know. I was using it as an obvious example for the OP to think about. eg a shape that has a centroid that's not on the surface of the shape.
| Sep12-12, 04:31 AM | #7 |
Yeah, I was probably thinking more about a centroid of a mass, but even then, there's still the donut which proves me redundant.
| New Reply |
| Thread Tools | |
Similar Threads for: Centroid of a C-Shape
| Centroid of an irregular shape | Introductory Physics Homework | 2 | ||
| Conversion from 'Shape*' to non-scalar type 'Shape' requested | Programming & Comp Sci | 10 | ||
| centroid of shape | Introductory Physics Homework | 4 | ||
| Centroid of the following shape | General Math | 0 | ||
| Shape Shape-shifting strings... solids, liquids, and gasses | Beyond the Standard Model | 2 | ||
