Create Variable Inductance in SPICE
Creating a variable inductance in SPICE, particularly in NI Multisim, involves using a polynomial voltage-controlled current source in parallel with a standard inductor (L0). The challenge lies in determining the appropriate coefficients for the current source to accurately model the desired inductance behavior. For those aiming to replicate a specific saturable inductor, measuring and curve fitting the inductor's characteristics is essential. Resources like the provided PDF can offer additional guidance on the implementation. Proper configuration can lead to successful modeling of variable inductance in simulation environments.
akhurash
I'm trying to create a variable inductance in SPICE, specifically in NI Multisim. What I'm trying to do is create a saturable inductor. I need an inductor that changes it's inductance with current. Multisim does have a "virtual" inductor that you can create a inductance function with but I can't really get it to work and I used NI but their help isn't that great either.
Has any created a variable inductor or a saturable inductor in some sort of a SPICE program (or Multisim)?
Any help is greatly appreicated. Thanks!
It's pretty easy. You just put a polynomial voltage controlled current source in parallel with the L0.
The trick is, what do you set the coefficients to. If you're trying to match an actual particular inductor, you're probably going to have to measure and curve fit it.
See page 2 of this PDF.
http://www.intusoft.com/articles/inductor.pdf
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
