Create Inductance Vs. Current Analysis/Graph in SPICE (Multisim)
Creating an Inductance vs. Current graph in SPICE (NI Multisim) requires setting up a test bench, as there is no dedicated GUI panel for this analysis. Users can utilize the "User Defined Analysis" feature under Simulate -> Analyses to configure their tests. By copying a specific schematic and varying resistance (R), one can observe changes in direct current (Idc) and the corresponding phase shift to analyze inductance behavior. This method allows for a practical examination of inductance as it relates to current. The discussion emphasizes the need for manual setup rather than relying on automated tools.
akhurash
Is there a way to create an Inductance vs. Current analysis/graph in SPICE (NI Multisim)? In Multisim there is a "User Defined Analysis..." under Simulate -> Analyses and I was wondering if someone knows how to configure this or did some sort of application related to this.
Thank You.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
