DivGradCurl
- 364
"Astronomers use a technique called stellar stereography to determine the density of stars in a star cluster from the observed (two-dimensional) density that can be analyzed from a photograph. Suppose that that in a spherical cluster of radius [tex]R[/tex] the density of stars depends only on the distance [tex]r[/tex] from the center of the cluster. If the perceived star density is given by [tex]y(s)[/tex], where [tex]s[/tex] is the the observed planar distance from the center of the cluster, and [tex]x(r)[/tex] is the actual density, it can be shown that
[tex]y(s) = \int _s ^R \frac{2r}{\sqrt{r^2 - s^2}}x(r)\: dr[/tex]
If the actual density of stars in a cluster is
[tex]x(r)=\frac{1}{2}(R-r)^2[/tex]
find the perceived density [tex]y(s)[/tex]."
I've tried working with the aid of a technical computing software, but it doesn't make things clear to me right now---although I have the solution:
[tex]y(s) = \int _s ^R \frac{2r}{\sqrt{r^2 - s^2}}\: x(r)\: dr = \left. \frac{1}{3}\sqrt{r^2 - s^2} \left( r^2 - 3rR + 3R^2 + 2s^2 \right) -Rs^2 \ln \left( r + \sqrt{r^2 - s^2} \right) \right] _s ^R[/tex]
[tex]y(s)=\frac{1}{3}\sqrt{R^2 - s^2}\left( R^2 + 2s^2 \right) - Rs^2 \ln \left( R + \sqrt{R^2 - s^2} \right) - \left( -Rs^2 \ln s \right)[/tex]
[tex]y(s)=\frac{1}{3}\sqrt{R^2 - s^2}\left( R^2 + 2s^2 \right) + Rs^2 \ln s - Rs^2 \ln \left( R + \sqrt{R^2 - s^2} \right)[/tex]
I couldn't find any reference in my table of integrals to help me understand this better. Maybe you guys can explain me how this integration is carried out. Any help is highly appreciated.
