A thermal physics question about steam and coffee, please could you help?
slingboi
A coffee machine in a café passes steam at 100°C into 0.18kg of cold coffee (s.h.c. the same as that of water(4200j/kg/K)) to warm it. If the initial temperature of the coffee is 14°C, what mass of steam must be supplied to raise the temperature of the coffee to 85°C
E = mcΔθ
possibly E = ml ?
I have thought.
E = mcΔθ
= (0.18)(4200)(71)
= 53676J
so 53676J of energy is needed to increase the temperature of the cold coffee from 14°C to 85°C
OK so the steam is at 100°C so it is at 373.15K
how can I use the temperature of the steam to find out how much steam would be needed to increase the temperature of the cold coffee to 85°C?
Would the steam need to be condensed?
How could i go about finding out how much energy a unit of mass of steam would have?
E = mcΔθ
possibly E = ml ?
I have thought.
E = mcΔθ
= (0.18)(4200)(71)
= 53676J
Yes, you need to condense the steam. Look up the heat of vaporization of water at its normal boiling point 100C.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
