cmmcnamara
- 121
- 2
Show that for an isentropic compression/expansion process that Pv^k=constant
The usual thermodynamic potentials, maxwell relations
The solution I am arriving at follows that of the solutions manual, but there is a substitution they use in the proof that is non-intuitive to me.
s=s(P,v)
ds=\left(\frac{∂s}{∂P}\right)_vdP+\left(\frac{∂s}{∂v}\right)_Pdv
Since the process is isentropic, ds=0, and using maxwell substitutions we arrive at:
dP-\left(\frac{∂P}{∂v}\right)_sdv=0
This is where our proofs are the same, they then diverge by making the substitution, and dividing by pressure:
k=-\frac{v}{P}\left(\frac{∂P}{∂v}\right)_s
\frac{dP}{P}+k\frac{dv}{v}=0
lnP+klnv=constant
Pv^k=constant
I don't find their substitution very intuitive. They describe it as the isentropic expansion coefficient. I do not understand how they can treat it as a constant however in the differential equation. Likewise, I feel that by their solution, if k can be treated as a constant then I would expect the partial differential component could be treated as such as well and the portion I had completed could be used to arrive at an algebraically different equation that could be rearranged but I don't see it. Can anyone help me understand the reasoning behind all of this?
NOTE: Later as a part of the problem it asks to prove that k reduces to the ideal gas ratio, for an ideal gas. I also tried working it from that angle but to no avail.
