How Do You Evaluate (1+i)^(1-i) and Describe the Set {1^x} for Real x?
cummings12332
Evaluate {(1+i)^(1-i)} and describe the set{1^x} when x is a real number, distinguish between the cases when x is rational and when x is rational. for now considering the complex number.
2. The attempt at a solution
i don't know how to start with,for firest part i just write it into e^((1-i)log(1+i)) then get the number with e to the power which inculding i , and the secound part , for 1=e^(i2npi) then 1^x is e^(2inxpi) then how to consider the case for rational and irrational here?????
start by breaking the factor into two factors (1+i)^1 * (1+i)^(-i)
i can do the first part now, many thanks ,but i don't understand the secound part of the question.should it be if 1=exp(2ikpi) then 1^x= exp(2ikpix) then consider the rational and irrational case on this form. but what's the differences , i have no idea
Yes. Think about whether different values for k can produce the same value.
if rational, then 1^(p/q) is the q complex roots of 1, if x is irrational then 1^x=exp(2ikpix) then k can be chosen infinitely many values then there are infinite points
That's it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
