| New Reply |
Definition of potential energy |
Share Thread | Thread Tools |
| Nov29-12, 05:49 PM | #1 |
Why is change in potential energy is defined as
PE1 - PE0 = -W I mean I could see it for example for gravity if we took PE0 to be zero at ground and we integerated -mgy(y^) we get -mg(y0 - y1) -> -mgh,but is their a proof somewhere where it shows it will be always negative work ? Thank you. |
| Nov29-12, 11:14 PM | #2 |
Recognitions:
It won't always be negative work. If the potential energy increases, PE1 > PE0, so W < 0. That says that rather than doing work the system absorbed work. If the potential energy reduces, PE1 < PE0, so W > 0.
| Nov30-12, 01:47 AM | #3 |
W, is work, defined as energy lost from the system. If energy is gained, the system has lost negative work. It's just a convention of direction of energy flow between environment and system.
| Nov30-12, 06:28 PM | #4 |
Thank you guys that makes perfect sense.
| Nov30-12, 09:11 PM | #5 |
Mentor
The force that you exert on the object as you lift it is equal in magnitude and opposite in direction to the gravitational force on the object. Therefore the gravitational force does work on the object that is equal in magnitude but with opposite sign to the work that you do. Therefore we can also write PEfinal - PEinitial = -Wgravity |
| New Reply |
| Thread Tools | |
Similar Threads for: Definition of potential energy
| A definition of a Potential Well | General Physics | 7 | ||
| Gravitational Potential Energy, Elastic Potential Energy, and Kinetic Energy | Introductory Physics Homework | 3 | ||
| Electric potential energy and gravitational potential energy of Deuterium nuclear? | High Energy, Nuclear, Particle Physics | 1 | ||
| Electric potential energy and gravitational potential energy of Deuterium nuclear? | Advanced Physics Homework | 1 | ||
| Gravitational Potential Energy Definition | Classical Physics | 1 | ||
