Why do triangular shapes work best for distributing weight in bridge building?
  • Thread starter Thread starter HeJind
    Load Weight
Triangular shapes are optimal for weight distribution in bridge building due to their intrinsic strength, as they maintain their shape under pressure. Unlike other polygons, altering a triangle's angles necessitates changing the length of its sides, ensuring stability. This structural integrity allows for effective load distribution, particularly when pressure is applied to the center of the bridge. Understanding which sides are under tension and compression is crucial for design; typically, the base of the triangle experiences compression while the apex experiences tension. Utilizing triangles in truss designs can significantly enhance the load capacity of structures, as evidenced by previous successful builds.
HeJind
Sorry if my English is bad. We're building bridges and learning about truss and truss variations, but I'm still confused as to why the triangular shapes work best and what they achieve. How would I know side would be compressed and which would be tense?
We have to build a bridge using roughly 10 dozen popsicle sticks. If I want to apply pressure/load to the middle, how would I design the bridge to distribute this evenly?
Apparantly last year someone got over 570llbs
Triangles "work best" because they're the only convex polygon that has intrinsic strength. You cannot change any angle of a triangle without also changing the length of one of the sides. You can change the angles of any other convex polygon without changing the length of any side; e.g. a square can be deformed into a parallelogram.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
