New Reply
Is permissible stress and tensile strength the same?
Share Thread Thread Tools
Dec7-12, 03:06 PM   #1
Hi, I am trying to find out if permissible stress and tensile are the same.If not,what is their relation?Thank you.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Dec7-12, 03:28 PM   #2
First thing to decide is if you mean tensile strength as in your title or tensile stress as your post implies.
Tensile stress refers to a type of stress.
Strength refers to the maximum possible stress of that type that can be applied without failure.
So tensile strength refers to the maximum possible tensile stress, at which point the subject fails.
Permissible stress refers to an amount of stress that will not cause failure.
You should look up 'factor of safety.'
This is the ratio of the strength to permissible ie maximum to permissible and is usually in the range 2.5 : 1 to 8 :1.
Dec7-12, 03:34 PM   #3
Quote by Studiot View Post
Thank you very much for your response 'Studiot'.
I refer to tensile strength.I know this relation with the factor of safety,but I just have the Lewis factor and premissible stress of the gear,and the calculator for maximum load through Lewis equation requires the tensile strength.I dont have the factor of safety.
Is there any other way to find tensile strength?
Thanks again.
Dec7-12, 06:30 PM   #4
section 7.5 here for instance provides various safety factors.
http://nptel.iitm.ac.in/courses/IIT-...II/pdf/2_7.pdf
You should note that such factors in modern design are compound factors and are called load factors.
Modern design also provides factors applicable to the strength of a material. The strength used is known as the 'characteristic strength' and is measured according to some standard scheme.
Edit
Please note further that you either apply the safety factor to the stress to achieve a safety factor and use the actual nominal loads.
This is the older simpler method called the permissible stress approach.
or
You apply the safety factors to the loads and material properties but use the actual stresses calculated.
This is the more modern, more complicated method, known as limit state analysis.
You do not apply both.
New Reply
Thread Tools
Similar Threads for: Is permissible stress and tensile strength the same?
Thread Forum Replies
Finding flexural compressive stress and tensile stress Engineering, Comp Sci, & Technology Homework 2
Tensile Strength and Tensile Strain Mechanical Engineering 9
Truss stress... compressive/tensile stress Mechanical Engineering 1
What is tensile strength? Introductory Physics Homework 18
Tensile strength General Physics 3
