How Is Maximum Kinetic Energy Calculated for an Object on a Circular Path?
  • Thread starter Thread starter duplaimp
    Energy Maximum
The discussion revolves around calculating the maximum kinetic energy of an object moving in a circular path, specifically with a radius of 0.5 meters and a tension limit of 16N in the rope. Participants explore the relationships between tension, mass, and velocity in the context of circular motion.
  • Mixed
  • Participants attempt to relate tension to mass and gravitational force, question how to find velocity, and explore the implications of circular motion on acceleration. There are discussions about rearranging equations and the necessity of mass in calculating kinetic energy.
Some participants have provided hints and guidance on the relationships between force, mass, and acceleration. There is an ongoing exploration of the correct approach to find kinetic energy without needing to determine mass explicitly. Multiple interpretations of the problem are being examined.
Participants note that there is insufficient information to determine mass directly, leading to confusion about its necessity in calculating kinetic energy. The constraints of the problem and the assumptions about the relationships between the variables are under discussion.
duplaimp
Hi,
I am trying to solve a problem but I can't figure how to continue..
There's an object moving in a circular path with radius 0.5m in an horizontal surface. The rope will break if the tension exceeds 16N. What is the maximum kinect energy?
So r = 0.5m
T = 16N
K=[itex]\frac{1}{2}[/itex]m[itex]v^{2}[/itex]
How can I find m and v? I tried with T = mg <=> 16 = m(9.8) <=> m = 1.63kg but I don't know if it is correct. But besides that I can't figure how to find v
Hint: Make use of the fact that the motion is circular.
I also tried that
v = [itex]\sqrt{a*r}[/itex]
But how to find a? Will it be g?
yes..
It is solved :) Thanks!
duplaimp said:
I also tried that
But how to find a?
Just rearrange that to write a in terms of v and r. Then apply Newton's 2nd law.
Will it be g?
No.
No.
But with that I don't get the right answer. Just to confirm: is the mass correct?
Show what you did with it.
You mean the value of the mass you calculated in post #1? No, that's not correct. For some reason, you set the tension equal to the weight of the mass. Why would you do that?
Hint: You don't need the mass to answer the question. It asks for kinetic energy, not mass.
a = [itex]\frac{v^{2}}{r}[/itex] and then F = m*a <=> F = m*[itex]\frac{v^{2}}{r}[/itex]
<=> 16 = 1.63 * [itex]\frac{v^{2}}{0.5}[/itex]
But since 1.63 isn't right it will give wrong results
I did that because I couldn't figure any other way to find the mass.. trial and error
But K=[itex]\frac{1}{2}[/itex]m[itex]v^{2}[/itex] so I need the mass
Perfect so far.
Yes, your value for mass is wrong. (Hint: There's not enough information to determine the mass. But you don't need it!)
You do not need the mass, you need the kinetic energy. So you just need to solve for 1/2mv2. Go back and stare at the first equation in this post.
Doc Al said:
Perfect so far.
Ok, finally I figured that :P
So, i did this:
F = ma <=> a = [itex]\frac{F}{m}[/itex]
a = [itex]\frac{v^{2}}{r}[/itex] <=> [itex]v^{2}=a*r[/itex] <=> [itex]v^{2}=\frac{F}{m}*r[/itex]
K = [itex]\frac{1}{2}*m*\frac{F*r}{m} = \frac{1}{2}*F*r[/itex]
Thanks!
So, i did this:
Thanks!
Cool.
A short cut would be to recognize mv2 when you see it:
[tex]F = \frac{m v^2}{r}[/tex]
Thus:
[tex]m v^2 = F r[/tex]
[tex]\frac{1}{2}m v^2 = \frac{1}{2}F r[/tex]
  • · Replies 26 ·
  • · Replies 19 ·
