IC Tube Packaging Solutions: Rubber Stoppers for IC Packages
  • Thread starter Thread starter Jiggy-Ninja
    Ic
The discussion focuses on the difficulty in finding the proper term for shipping tubes used for DIP IC packages. Participants express frustration with search results on platforms like Amazon and Google, which yield irrelevant information. A suggestion is made to use the term "anti-static IC shipping tubes" for more effective searches. Additionally, there is interest in sourcing rubber stoppers that effectively seal these tubes. The conversation concludes with a shared acknowledgment of the helpfulness of the suggested search term.
Jiggy-Ninja
What is the proper term for those tubes that DIP IC packages come shipped in? Searches on Amazon and Google are fruitless and Mouser/Digikey is hopeless unless you know exactly what you're looking for and exactly where it is. A link or even just the right words to use would be appreciated.
Also looking for some rubber stoppers like the ones shown in the pic. Out of all the ways of stopping up the end I've had my ICs shipped with, those are the best.
I've always just called them IC tubes. Do you think there is another name for them?
It's not so much that I want to know what they're called, it's that I want to buy some and can't find them when I search for "IC tube". Amazon has nothing and Google comes up with references to some medical condition.
Ah. The helpful search term is anti-static. Try a Google search on anti static ic shipping tubes. I got lots of good hits. How does it work for you?
That's the magic word, thank you.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
