New Reply
Entropy of a continuous system
Share Thread Thread Tools
Feb20-13, 06:55 PM   #1
How could the entropy of a continuous system, like the electromagnetic field, be defined? Obviously you can't use something like the log of the phase space volume, but I can't think of anything that would work.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Feb20-13, 07:10 PM   #2
Recognitions:
If you can assign a temperature (which you can for blackbody radiation), you can define the entropy:
http://128.113.2.9/dept/phys/courses...BodyThermo.pdf
Feb20-13, 11:09 PM   #3
Why do you think so? I think you may be right, since the number of Fourier variables (harmonic oscillators) is infinite, which makes the energy infinite.
Feb20-13, 11:33 PM   #4
Recognitions:
Gold Membership Gold Member
What's wrong with phase space volume? You can still write the Hamiltonian for a continuous system - it would just be a field theory now.
Feb21-13, 05:47 PM   #5
Quote by Andy Resnick View Post
Thanks for the paper, but I'm looking for a more statistical approach.
Quote by Jano L. View Post
Quote by Jorriss View Post
Well, the phase space of a field is infinite dimensional. I wouldn't even know how to define volume, and if I could I'd think the volume of basically any region would be infinite.
Feb21-13, 08:27 PM   #6
Recognitions:
Quote by dEdt View Post
Google is your friend:
http://home.comcast.net/~szemengtan/...lMechanics.pdf
Section 5.3
Feb22-13, 12:46 AM   #7
Rap
Use the entropy density (entropy per unit volume). It will, of course, not be conserved except for reversible situations. In general, there will be a rate of entropy creation per unit volume due to irreversible processes. If s is entropy density, then [tex]\frac{\partial s}{\partial t}+\nabla \mathbf{J}_s=\frac{\partial s_c}{\partial t}[/tex] where s is entropy density, [itex]\mathbf{J}_s[/itex] is the entropy flux, and [itex]\partial s_c/\partial t[/itex] is the rate of creation of entropy density (always non-negative).
For example, for a simple fluid, the fundamental law says [itex]dU=T dS-P dV+\mu dN[/itex] where U is internal energy, T is temperature, S is entropy, P pressure, V volume, [itex]\mu[/itex] chemical potential, and N the number of particles. So it follows that [itex]dS=(1/T)dU+(P/T)dV-(\mu/T)dN[/itex] and in terms of densities: [tex]\frac{\partial s}{\partial t}=\frac{1}{T}\frac{\partial u}{\partial t}-\frac{\mu}{T}\frac{\partial n}{\partial t}[/tex] where u is internal energy density and n is particle density. And so forth.
In statistical mechanics terms, you are considering each infinitesimal volume element to be an open equilibrated system. To find the total entropy, integrate the entropy density over the total volume.
New Reply
Thread Tools
Similar Threads for: Entropy of a continuous system
Thread Forum Replies
Continuous Time Fourier in LTI system Engineering, Comp Sci, & Technology Homework 1
Continuous system & Infinite d.o.f. Mechanical Engineering 1
Solutions to continuous dynamical system Calculus & Beyond Homework 1
Entropy of a system General Physics 2
entropy of a system? Classical Physics 6
