How can the pebble stay on the wheel as it rolls?
  • Thread starter Thread starter cacofolius
    Wheel
The discussion focuses on the conditions under which a pebble released on top of a rolling wheel will remain on the wheel. It establishes that if the wheel's velocity V exceeds the threshold of sqrt(Rg), the pebble will immediately fly off due to insufficient centripetal acceleration to counteract gravity. The contributor attempts to clarify their understanding by analyzing the tangential velocity and the distance involved, concluding that V=sqrt(Rg/2) is a key point. They also mention the advantage of switching to a reference frame moving with the wheel's axle for simplification. Overall, the thread emphasizes the relationship between velocity, centripetal acceleration, and gravitational forces in this scenario.
cacofolius
A wheel of radius R rolls along the ground with velocity V.
A pebble is carefully released on top of the wheel so that it is instantaneously at rest on the wheel.
Show that the pebble will immediately fly off the wheel if V> sqrt(Rg)
Hi, I know this problem's been asked before, but since they're old posts, and didn't quite understood the clues given there, I decided to ask one more time.
I understand that if the centripetal acceleration equals or is less than gravity, then the pebble will not immediately fly off, but in this case the tangential velocity at the top will be 2v (taken from the floor), and thus the distance will be 2R. Therefore
(2v)^2/(2R)=g and V=sqrt(Rg/2)
I feel I'm missing something, any hints will be appreciated
From the point of view of the reference frame at rest with respect to the ground, a point on the rim of the wheel travels along a cycloid. So, the radius that you would need to use is the radius of curvature of a cycloid at the highest point.
You can avoid all that by going to the frame of reference moving with the axle of the wheel.
Oh, then its more simple. Thanks!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
