Why in smithchart 360 degree corresponds to half the wavelength
  • Thread starter Thread starter dexterdev
    Degree Wavelength
In a Smith chart, 360 degrees corresponds to one full wavelength (λ), but a half wavelength (λ/2) represents a significant change in the reflection coefficient. A short circuit on a transmission line has a reflection coefficient of -1, plotted on the left side of the Smith chart. Lengthening the transmission line by 1/4 wavelength transforms the reflection coefficient to +1, resembling an open circuit, and moves the point to the right side of the chart. This movement illustrates that extending the line by 1/4 wavelength effectively shifts the point halfway around the Smith chart. Understanding this relationship is crucial for accurate impedance matching in RF applications.
dexterdev
Hi,
Actually wavelength λ corresponds to 360 degrees , right? then why λ/2...
Don't expect Smith chart to work like an Argand diagram.
Consider a short circuit on an electrically short transmission line. This will have reflection coefficient of -1, which will be plotted on the far left side of Smith chart. If I lengthen transmission line by 1/4 wavelength in front of short circuit, it will have a reflection coefficient of +1 (i.e. it will look like an open circuit), which will be plotted on the far right hand side of Smith chart. Extending transmission line 1/4 wavelength moved us halfway around Smith chart.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
