Do Boundary Conditions Limit Nozzle Exit Velocity?
  • Thread starter Thread starter Jonny6001
    Nozzle
The discussion focuses on the effects of boundary conditions on the exit velocity of a supersonic converging-diverging nozzle. It establishes that the maximum exit velocity is fundamentally limited by the total temperature in the reservoir, as defined by the equation u_{\text{max}}^2 = \dfrac{2a_0^2}{\gamma -1}, where a_0 is the speed of sound based on the total temperature T_0. The conversation also highlights that the maximum mass flow rate through the nozzle is determined by the choked flow condition, expressed as \dot{m} = \dfrac{p_{01}A^*}{\sqrt{T_{01}}} \sqrt{\dfrac{\gamma}{R}}\left( \dfrac{2}{\gamma+1} \right)^{\frac{\gamma +1}{2(\gamma-1)}}. Increasing inlet temperature or pressure can enhance the exit velocity, but only within the constraints of the nozzle geometry and exit pressure.
  • Understanding of thermodynamics, particularly the concepts of total temperature and specific heats.
  • Familiarity with fluid dynamics, specifically the behavior of compressible flow in nozzles.
  • Knowledge of the energy equation and enthalpy in the context of gas dynamics.
  • Basic grasp of nozzle geometry and the concept of choked flow.
  • Study the derivation and implications of the energy equation in compressible flow.
  • Learn about the effects of varying inlet conditions on nozzle performance.
  • Research the principles of choked flow and its significance in nozzle design.
  • Explore specific nozzle geometries and their impact on flow characteristics and exit velocity.
Aerospace engineers, mechanical engineers, and students studying fluid dynamics or thermodynamics, particularly those interested in nozzle design and performance optimization.
Jonny6001
Hello,
I am interested in the boundary condition effects on a converging-diverging nozzle.
If you have a certain inlet pressure and temperature to a supersonic converging-diverging nozzle which exits into a the outlet pressure, is there a limit to the velocity that you can generate at the nozzle exit?
I mean as the gas velocity speeds up in the diverging section the temperature and pressure reduce. If the local nozzle static pressure gets too low relative to the exit pressure then you over-expand the gas and shocks form inside the nozzle.
Does this mean that the inlet and exit pressures limit the maximum exit gas speed that can be reached? And short of increasing the inlet pressure or decreasing the exit pressure no further velocity increase can be had? Would increasing the inlet temperature with the same inlet pressure increase the available expansion?
Thank you.
Assuming you are using a thermally and calorically perfect gas, then the maximum velocity that can be achieved from a given reservoir condition depends entirely on the total temperature in that reservoir. You can start with the energy equation and the definition of enthalpy and derive the following relation:
[tex]u_{\text{max}}^2 = \dfrac{2a_0^2}{\gamma -1}[/tex]
where [itex]a_0 = \sqrt{\gamma R T_0}[/itex] is the speed of sound based on the total temperature in the reservoir [itex]T_0[/itex] and [itex]\gamma[/itex] is the ratio of specific heats and [itex]R[/itex] is the specific gas constant.
Of course, that is the maximum theoretical velocity regardless of nozzle geometry. If you have a more specific nozzle geometry in mind you can get more information. For example, for a given nozzle, the maximum mass flow rate that you can get through the nozzle is based on the point where the nozzle becomes choked and can be shown based on conservation of mass to be
[tex]\dot{m} = \dfrac{p_{01}A^*}{\sqrt{T_{01}}} \sqrt{\dfrac{\gamma}{R}}\left( \dfrac{2}{\gamma+1} \right)^{\frac{\gamma +1}{2(\gamma-1)}}[/tex]
where [itex]p_{01}[/itex] and [itex]T_{01}[/itex] are the total pressure and temperature respectively in the reservoir and [itex]A^*[/itex] is the throat area.
Other flow variables like the velocity for a given nozzle geometry (most importantly [itex]A_e/A^*[/itex]) are relatively easily calculable, though it is slightly more involved than above.
  • · Replies 26 ·
