Van de Graaff Generator - Shock vs. No Shock?
The discussion revolves around the differences in sensations experienced when using a Van de Graaff generator in two scenarios. In the first scenario, minimal sensation is felt when a nail is used to touch a grounded discharge electrode, likely due to charge leakage from the body reducing the potential difference. In the second scenario, a significant shock is felt when a neon gas tube is brought close to the generator, as the charge builds up sufficiently to create a large arc discharge. Participants clarify that the sensation is concentrated at points of entry and exit on the body, and that using a larger contact area (like the nail) results in less sensation compared to a smaller area (like a fingertip). The conversation concludes with insights on charge buildup and the importance of proximity to the generator for experiencing shocks.
tomcat017
Hello all,
I have a quick, albeit probably ignorant (forgive me) question generated by (bu dum) observations of a van de graaff generator.
In particular, two distinct scenarios caused me to question what was going on.
Scenario 1 – I’m standing on a plastic stool, with one hand on the generator’s dome. I’m holding a nail in the other hand. I point the nail at a grounded discharge electrode, and hear the effects of escaping charge. I bring the nail close to the grounded electrode until (at a very close distance) visible arcs form. I then put the nail in contact with the discharge electrode. I feel no appreciable sensation.
Scenario 2 – I’m standing on the ground, in sneakers, not in contact with the generator dome. In one hand, I’m holding a neon-filled gas tube. I being the tube near the dome and hear charge escaping as the ionizing gas in the tube emits light. I feel no real sensation. I assume this is due to small amounts of charge leaking off of the dome. I get a bit too close, and a large (~6”) arc jumps from the dome to the gas tube. I’m holding the glass envelope, and feel…an appreciable sensation in my hand and in my right foot.
In both cases, I am serving as the conductor that connects the dome to the ground. In scenario #1, I feel nothing, while in scenario #2…definitely something. Why does this happen?
Here’s my preliminary suspicion – please correct me where I’m wrong. In scenario #1, lots of charge is leaking off my body (hair and fingers both relatively pointy). By the time the nail contacts the discharge electrode, potential difference is low (why the arc is so short), and so the sensation produced by resulting current is minimal. In scenario #2, the dome retains almost all of the 200 kV potential (it is a sphere), and none leaks (save minimal charge prior to reaching the critical distance) until I get close enough, and then – full discharge. The resulting current produces a substantial sensation.
Is that it? Or is there more/else to it?
Some follow-up questions.
1. When I got the shock sensation, why was it felt in my hand and foot, but not in between?
2. Does touching the discharge electrode with the nail result in less sensation that if I had contacted it with my finger? Why? Is there something special about the point where the arc occurs, as it pertains to sensation? More substantial that the current flowing from me into the nail without the arc?
3. Is there a better way to demonstrate gas ionization in this fashion (without taking the shock every time)?
4. There are videos on youtube of chains of 5-10 people in contact with the generator dome. When the last person in the chain is touched, there appears to be a substantial sensation. Why is the charge not leaking off the people (x10) in such large amounts that contacting the final person has no result? Moreover, since all of the people are standing on the floor, why does an 11th person (also standing on the floor) cause significant discharge/sensation? When he contacts the chain, he is no more grounded than each of the other participants, no?
Thank you in advance for any clarity you can provide! Please feel free to criticize my understanding, and please do forgive me if this is obvious to you.
Hi tomcat
welcome to the forums :)
I am no expert with this ... BUT experience is a good teacher ( if it doesn't kill ya)
others may fill in the gaps
cuz those are the concentrated points where the charge is entering and leaving your body
Yes using the nail would have that result. if you used your fingertip instead, the spark would have been leaving the concentrated area of your finger tip instead...
Think about the times you have walked across a carpet and got a zap when touching a doorknob
same thing ... if you had reached outto the door knob with nail instead you wouldn't have felt the zap.
... and also ... when you were charging up walking across the carpet, you didnt feel any different did you? even tho you had charged yourself up to 10's of 1000's of volts
of course ... DONT be part of the circuit ! :) set the fluorescent tuble up with one end grounded and the other end coming near the generator dome ( you and the others watch from the sidelines)
and this goes back to your prelim. comments. I think you will find that the charge leaking off you is rather slow and low. And that's why a person touching the end of the chain of people still gets a significant zap.
I haven't played with a VDG Gen. for many many years, but I suspect you will find, and you can try the experiment. Charge yourself up and remove your hand from the generator and do some timing to see how long you hold a significant charge for ...10 mins, 30 mins, maybe 1 hour ??
cheers
Dave
Thanks Dave! Appreciate all the explanation.
By the numbers:
1: so the only reason I feel the shock at the hand/foot (but not side of my body) is that the charge travels along the surface of my body in distributed form, but enters/exits at a very small point - thus the area is smaller, and the sensation, more significant. Is that correct? I can't believe I missed such a simple factor - thank you.
2: more of less the same. lots of nail-to-hand contact area, so less charge density and sensation. But if the arc exits from the finger, greater sensation due to the small area of hand-air surface through which the charge exits.
3: Unfortunately, the tube is only ~5" long, so it won't reach a convenient ground. I will try attaching a grounded wire to it, but it doesn't have any metal electrodes or convenient attachment points. It's just a glass envelope. I've seen it held by hand during demonstrations, and am now wondering if they just dealt with the resulting shock. It was a substantial discharge, and I would prefer not to do that twice every second just to demonstrate the gas ionization. :-)
4: I agree that charge leaking off the person should be small. That explains why after 10 people, the potential is still significant. Also explains why hair takes a long time to settle down once off the generator dome, but still insulated. However, if that's the case, how do we answer the original question?
In the original scenario 1 vs. 2, I had substantial contact area between my hand and the item being held (in #1, a nail; in #2, a glass tube). And yet in #1 I was fine, while in #2 I got juiced. If we don't explain this difference by citing large amounts of charge leakage from my body in case #1, then what explains the substantial jolt in #2?
By the numbers:
I believe that to be the reason, yes
again, Yes
OK would probabaly be easy enough to set it up on a stand od some sort ... even a microphone stand would be good, with its plastic clamp on the top to hold the neon tube
OK let's break down scenario #2 a bit more...
Yes, at this time you have stated there has been no arc/discharge from the dome to the tube you are holding.
Consider that there will be a significant electric field surrounding the dome and any object brough into that field is likely to have a charge induced into it.
Also remember that the tube and you have a much lower ( ummm ... trying to find the right words... ) "energy level" ... you don't have the hi charge on you that the dome has ( hope you figured what I meant)
OK now you have gone to a point close enough so that a discharge from the dome can occur and this discharge results in a large flow of charge from it to you via the neon tube. That fast build up of charge in you is also now high enough to discharge across your rubber etc sneakers.
This would be in a similar fashion to a lightning discharge from cloud to ground, where the charge needs to build up high enough to bridge the gap between cloud and ground. abd even before that discharge occurs there is a very hi electric field that had built up, which collapses when the discharge occurs. Then it starts to build up again till the next discharge occurs.
did that help ? :smile:
Dave
Yes - something you said at the end there caused me to wonder if this is the case:
Perhaps, with the nail (a pointy object, subject to lots of charge escape) being brought near the grounded discharge electrode, the amount of charge leaking off the nail progressively increases as I bring the two in proximity. The metal is a good conductor, and it's pointy. The progressive charge escape prevents a large potential difference, which prevents the more instantaneous discharge that's seen with the tube. The tube, which is not a conductor, or as pointy, loses less charge as I near the dome. Then, when the distance is sufficiently close, the electrical resistance of the air is suddenly overcome, and the charge drains very quickly.
I'm not convinced that the nature of the materials (conductor/insulator) explains that much difference in leaking charge...but...an idea?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
