Register to reply
Bore lapping/polishing
by will0057
Tags: bore, lapping or polishing
Share this thread:
will0057
#1
Apr25-13, 03:24 AM
P: 1
Hi - sorry I'm not an engineer just desperate!
I want to remove pitting and marking in a shotgun bore and am having problems finding a tool which will do this in the firearms sector - and if I do I am sure it will be at a premium price - removing a small amount ie less than a thou of the internal diameter of a bore and polishing must be a fairly common requirement in engineering - does anyone know of a cheap portable tool which will do this (as opposed to factory honing) I want something I can put on a drill and spin in the bore - have tried brake honing stones but really need something which will apply equal pressure (or nearly) at all surfaces of the bore, the nearest I can get so far is to try rig up an expanding mandrel - is their anything commercially available?
Thanks
Will
Phys.Org News Partner Engineering news on Phys.org
Philips introduces BlueTouch, PulseRelief control for pain relief
3-D printing leads to another advance in make-it-yourself lab equipment
Nanoscience makes your wine better
Danger
#2
Apr25-13, 05:51 AM
PF Gold
Danger's Avatar
P: 8,964
I'm not sure whether or not this will work for you, but it might be worth checking out. There are valve-guide hones for auto mechanics. I don't know how large a bore they can service, though. Also, you'd definitely want to rent or borrow one; they cost upward of $350.
My only other suggestion would be to wrap sandpaper or drywall screen around a sponge on a stick.
(That's not my final answer, but I've got nothing else right now.)
sophiecentaur
#3
Apr25-13, 08:04 AM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,267
Your bore is tapered, I imagine. That doesn't help.
How about a sponge mop and valve grinding paste? Lots of rotation and reciprocation to spread the wear and avoid high / low spots.
Register to reply
Related Discussions
Engineering Drawing: Pin/Bore Tolerances Engineering, Comp Sci, & Technology Homework 0
Science behind the bore feeling? Biology 8
Polishing bk7 General Physics 1
The bore on the river Classical Physics 1
What bore diameter will fit a 5.4mm motor shaft? Mechanical Engineering 4
