Register to reply
Heat transfer coefficient of cylinder in free air?
by Askara
Tags: coefficient, cylinder, free, heat, transfer
Share this thread:
Askara
#1
Apr28-13, 04:30 AM
P: 21
let say a cylinder(steel) is 6 cm diameter and length of 3.5 cm length. and is heated to 1000 degree c.
in a room of free air and room temperature of 20.
will convective heat transfer dominate? it radiation is negligible?
what would the convective heat transfer be?
what power(watt) is needed to maintain the 1000 degree ?
Phys.Org News Partner Engineering news on Phys.org
UConn makes 3-D copies of antique instrument parts
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
Alt-Bringer
#2
Apr28-13, 04:28 PM
P: 16
im assuming introducing an electric current into the cylinder is what heats it,
and that 1000c wont melt it (i dont know conversions)
and that "free" air means a normal environment (no vacum pressuer etc.)
i think convection or random air circulation would be the major dissapent of heat, if thats what you mean
hot metal from my very limited experiance dosent radiate well, ie you can put you hand near a fresh weld and as long as you dont touch it your fine
though radiators (house heat) obviously use radiation, you get a rather slow steady temp rise
by the small amount of convection pulling cool air tward it and normal air circulation spreading it around
thats not saying you dont get decent radiant heat, but that its kept to an area of a few inches
where as somthing like fire radiates in a relativley large area
mechwill
#3
Apr28-13, 11:52 PM
P: 5
If the steel cylinder is the only heat source in the system without any fan but the system has small air circulation, it is a natural convection. The melting point for steel is around 1370 C, so theoretically, it will not melt.
However, if you look at how the hot iron was taken out of the furnace and you see the red glowing part of the iron, it is primary light radiation heat transfer. Personally, I haven't seen if there is any red glowing part on the steel when it reaches to 1000C. But let's assume it's black steel.
Register to reply
Related Discussions
Typical value free air convection heat transfer coefficient General Engineering 5
Evaluating heat transfer coefficient for a cylinder Mechanical Engineering 0
Value of Heat transfer coefficient Mechanical Engineering 7
Is the overall heat transfer coefficient constant for a certain heat exchanger? Advanced Physics Homework 0
Heat Transfer Through a Cylinder Engineering, Comp Sci, & Technology Homework 1
