Combining Momentum with Friction
  • Thread starter Thread starter student34
    Friction Momentum
The discussion revolves around a physics problem involving a collision between a sedan and a truck, where both vehicles become enmeshed and slide after the impact. The key calculations involve determining the initial speeds of both vehicles using momentum conservation and frictional forces. Participants highlight the importance of using the correct components of acceleration and the relationship between work and energy in their calculations. There is confusion regarding the application of kinematic equations and the breakdown of work into components, leading to discrepancies in the calculated speeds compared to textbook answers. Clarifications emphasize the need to treat acceleration and displacement as scalar quantities in the context of the problem.
student34
A 1500kg sedan traveling from north to south is struck by a 2200kg truck that is traveling from east to west. The two vehicles become enmeshed due to the impact and slide thereafter. Measurements show the coefficient of friction between the tires and the road is 0.75. The two vehicles slide 5.39m west and 6.43m south of the point of impact. How fast was each vehicle traveling just before the collision?
P1x = P2x
P1y = P2y
P1x: mx*V2x = V2*(mx + my)
P1y: my*V2y = V2*(mx + my)
P1x = mx*Vt
P1y = V2*(my + mx)
P1y = my*Vy
Ffriction(x) = m(s + t)*a
Ffriction(y) = m(s + t)*a
a = g*μ
V2x = (-2*ax*xskid)^(1/2)
V2y = (-2*ay*yskid)^(1/2)
mx*V1x = V2y*(mx + my)
V2y = (2*9.8*0.75*6.43)^(1/2) = 9.722...m/s
V2x = (2*9.8*0.75*5.39)^(1/2) = 8.901...m/s
Now I will substitute V2y and V2x into the conservation of momentum equation:
my*V1y = V2y*(mx + my)
Isolating V1y = (9.722...m/s*3700kg)/1500kg = 23.98...m/s which is wrong because the textbook's answers are 12m/s and 21m/s. I get V1x = 14.97...m/s. Both are wrong by 3m/s, but I have no idea why.
P1x = P2x
P1y = P2y
P1x = mx*Vt
P1y = V2*(my + mx)
P1y = my*Vy
a = g*μ
You can't break the work (done by friction) into x & y components. Work is a scalar quantity, not a vector.
I didn't use work or any type of energy equations. I broke acceleration into x and y components.
The kinematic equation, (vx)2 = 2(ax)x
is equivalent to the work energy theorem (if you include all components).
Since you didn't use work explicitly, let's look at it this way.
For the kinematic equation, (vx)2 = 2(ax)x , you need to use ax, not a. Of course, use ay for to find vy.
The acceleration is in the same direction as the overall displacement. Use that to find its components.
I did that in the work in my original post.
I can't make sense of that. Do you mean mx*V1x = V2x*(mx + my) etc?
##v_{2x} = (-2 a_x*x_{skid})^{\frac12}##
As SammyS says, this is not valid. A correct form would be
##v^2 = (-2 a*s_{skid})## where ##v^2 = v^2_x+v^2_y; a^2=a_x^2+a_y^2; x_{skid}^2+y_{skid}^2 = s_{skid}^2##, or in vectors (because a and s are collinear) v.v = -2a.s.
Wow, I get it, thank you both so much!
That was much clearer than mine.
Thank you haruspex !
