Notation for Lists in Math: Symbol, LaTeX
  • Thread starter Thread starter HJ Farnsworth
    List Notation
A commonly accepted notation for lists in mathematics does not have a specific symbol analogous to the summation symbol (Ʃ). Instead, mathematicians often use set notation, such as {A_i}_{i=1}^n or simply A_i for i = 1, ..., n. LaTeX can represent these notations effectively, allowing for clear communication of indexed lists. While there is no single symbol for lists, these alternatives provide a clean and convenient way to express sequences. Overall, the discussion highlights the importance of clarity in mathematical notation.
HJ Farnsworth
Greetings,
Is there a commonly accepted notation for a list in mathematics, of an identical form to Ʃ for a summation? If so, what is the name of the symbol (that would be used in place of L, below), and how would it be typed in LaTeX?
For instance, it might look something like,
L^{1}_{n}Ai\equivA1,A2,...,An,
except that the 1 and the n on the LHS would be directly below and above the L, as they would be with Ʃ for a summation.
Obviously, this is not a critical issue, but I often run into situations where that notation would be convenient and cleaner than writing a full list or ...'s all of the time...
Thanks for any help you can give.
-HJ Farnsworth
Mathematics news on Phys.org
##\{A_i\}_{i=1}^n##
or ##\{A_i\}_{i\in I}## for some index set I (provided I is defined)
or just "##A_i## for ##i = 1, \ldots, n##"
Perfect, thank you very much.
-HJ Farnsworth
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
