What hands on trade would benefit an electrical engineer?
Hands-on trade skills can significantly benefit electrical engineering students, with suggestions including welding and woodworking. While woodworking offers practical home remodeling skills, welding may not directly apply to electrical engineering but can enhance employability in specific sectors like power plant construction. Engaging in wiring houses can provide relevant experience and financial benefits during studies. The discussion highlights the value of practical skills for both career readiness and personal use. Overall, pursuing trades that align with engineering principles can enhance job prospects and practical knowledge.
DeeJayCruiser
I'm going into my second year of a 2 year electrical technology diploma (technologists are like middle men between engineers and technicians), and got hooked on discovery channels' show "biggest brain theory" recently. More than anything, the documenting of the contestants' work in the workshops reminded me that there are a lot of great skills that are out there, but not necessarily ones that are covered in a standard curriculum.
I am debating between an intro to welding class, perhaps a woodworking class, or something along those lines, but between any of those trades classes does anyone have recommendations for something that would be more applicable and even beneficial in the field of elec. engineering?
Wood working in general is great because you are going to need that skill to survive in a house down the road. Or you can pay someone $25 to $35 an hour to work on your house for you who has these skills. However, it will not lend itself towards engineering. But, being able to fall back on this skill in recessions is a great asset. Basic home remodeling skills are always great on any level.
Welding is good if you are into cars and motorcycles or that sort of thing. Clearly, to make a weld you need a lot of electricity, but again it doesn't really lend itself to electrical engineering. Most people don't need things welded too often, so if you do need a welder prob just better to pay someone. If you do have tons of welds to do down the road, great...go learn it and it will benefit you down the road.
However, a side job wiring houses absolutely lends itself to electrical engineering. Make money now and you will be more prepared for school. Again, you can fall back to it in recession times as well.
thanks psparky. Welding does interest me, but as you mentioned it's probably unlikely that I'll be welding things on my own, while wood-work will likely be commonplace throughout my life.
Appreciate the feedback!
Welding engineers enjoy terrific employability in power plant construction and maintenance.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
