What is the difference between water evaporation and boiling?
Water evaporation and boiling are distinct processes influenced by temperature and vapor pressure. Evaporation can occur at normal temperatures when higher energy molecules escape from the liquid's surface, while boiling happens when the vapor pressure equals the ambient pressure, typically at 373.15K for water. The energy distribution among molecules plays a crucial role, as not all molecules have the same energy level, allowing some to escape even at lower temperatures. Factors like environmental conditions, such as airflow, can enhance evaporation by reducing the number of returning molecules. Understanding these differences clarifies why water can dry without reaching its boiling point.
Ferraridude
I have recently wondered how water can dry at normal, livable temperatures, but its boiling point is 373.15K. Is there a difference between drying water and boiling it into a gas?
This might be better served in the chemistry section for reasons I'm about to explain.
So this property of evaporation vs boiling strikes a lot of people as being sort of odd, but the answer lies in the very nature of liquids. So, all (maybe most?) have a 'vapor pressure,' that is, there are some free molecules of the liquid that rest just above the liquid itself. Even mercury technically has a vapor pressure, albeit quite small.
Liquids, and some solids, exhibit vapor pressure because of chance and, more importantly, the energy distribution of a group of molecules at the same temperature. Not all the molecules in a collection are at the same energy level, and the usual entropy obeying model shows that most of the molecules of a collection are in the lowest state and some in the 'middle' state and just a few in the highest state (this is pretty simplistic but you get the idea).
These higher energy molecules can escape sometimes on the surface of the liquid as the weak bonds of the liquid can't hold every molecule in all the time. If you're in a closed environment, these molecules will escape into the area above the liquid until you reach a sort of equilibrium position, where the rate of chance escaping molecules equals the chance returning molecules that have drifted back down.
If you raise the temperature of the liquid, you get a higher energy distribution in which more molecules have the energy required to escape one by one, so the vapor pressure will rise. This is why being in a location that's warm and wet causes 'humidity.'
So evaporation can occur when the liquid is at a reasonable temperature and is exposed to an open environment, or one where the vapor molecules are easily swept away, think blowing a fan over warm water. This would cause the rate of returning molecules to drop, but the rate of exiting molecules would be mostly unchanged or rise due to the turbulence of the wind or whatever is going on in your environment.
Boiling occurs when, and this is quite cool, when the vapor pressure of a liquid has reached the ambient pressure (usually atmospheric pressure). So when you heat a liquid, the energy distribution rises and rises until most of the molecules are in a high enough state to exert an equal pressure on the atmosphere. Once this occurs, molecules will escape en masse.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
