Rod + 2 Particle masses = angular acceleration
The problem involves a rigid rod rotating in a vertical plane about a pivot, with two particles attached at its ends. The goal is to determine the angular acceleration of the system when the rod is at a specific angle with the horizontal.
  • Participants discuss calculating the moment of inertia for the rod and the attached particles, as well as the net torque based on gravitational forces. There is uncertainty about the correct angle to use in torque calculations and whether the approach to finding net force is appropriate.
Some participants have provided detailed calculations and identified potential errors in the original poster's approach. There is an ongoing exploration of the correct application of torque and moment of inertia concepts, with no explicit consensus reached on the resolution of the problem.
Participants note confusion regarding the angles involved in torque calculations and the treatment of forces acting on the particles. The discussion reflects a collaborative effort to clarify these concepts without arriving at a definitive solution.
ninjagowoowoo
PROBLEM:
A rigid rod of mass 8.70 kg and length 2.30 m rotates in a vertical (x,y) plane about a frictionless pivot through its center. Particles m1 (mass=4.30 kg) and m2 (mass=2.60 kg) are attached at the ends of the rod. Determine the size of the angular acceleration of the system when the rod makes an angle of 50.1° with the horizontal.
I tried getting the moment of inertia using Irod = 1/12ML^2 + the Is of both the particles. Then I found the weight difference and used that to compute torque in torque = r x F. Finally I used those two answers to get angular acceleration. Of course this is wrong... can someone help me please? Or at least tell me what I did wrong... I think I may be confused about the angle between r and F. Anyway, any help would be apperciated! Thanks.
i have that problem for my physics hwk too :smile:
haha, do you go to UCSB?
This should work just fine. Show in detail what you did and then we can try to spot any errors.
Irod = (1/12)ML^2 = (1/12)(8.7kg)(2.3^2)=3.83525
Iparticles = m1r1 + m2r2 = 4.3(1.15) + 2.60(1.15) = 7.935
Inet = 11.77025
Force due to gravity(net) = m1g - m2g = 42.14N - 25.48N = 16.66 N
Now this is the part where i think i may be wrong:
since the angle between r and the horizontal is 50.1 deg, then the angle between r and F is 140.1 deg.:confused:(I did try it with 50.1 deg and still no luck.)
Thus:
torque = rF(sin140.1)= 12.28953349
torque = I(alpha) = 12.28953349 = 11.77025(alpha)
so alpha = 1.04411 rad/s/s
which is wrong... is my angle wrong or is there more to it than that? Thanks for the help.
Here's your error: the moment of inertia of a particle is [itex]mr^2[/itex], not [itex]mr[/itex].
Subtracting the weights of the two particles to find the net force is a shortcut that is OK here, since they happen to be equidistant from the pivot point. But each particle should be thought of as exerting its own torque, not just its own weight. You need to find the net torque, not the net force.
That's perfectly OK. Since you don't know whether the heavier particle is above or below the horizontal, the angle could be 140.1 deg or 39.9 deg. But it doesn't matter, the torque is the same.
  • · Replies 18 ·
  • · Replies 62 ·
14K
