Question regarding inverse functions
The discussion centers on whether the inverse of the function f(x+3) is equal to f-1(x+3). It is argued that this statement is false because finding an inverse typically involves switching the x and y variables, which would not preserve the original function's form. An example is provided where f(x) = 2x + 3, leading to a calculation that shows f-1(x+3) does not equal the inverse of f(x+3). The conversation emphasizes the importance of testing with specific functions to clarify the relationship between a function and its inverse. Ultimately, the conclusion is that the proposed equality does not hold true in general.
michellemich
f(x) where x belongs to all real numbers
inverse: f-1(x), where x belongs to all real numbers
True or False:
The inverse of f(x+3) is f-1(x+3)
My ideas:
I think that it is false given that when you usually find the inverse of a function, you switch the x and y variables and solve for y again meaning that the inverse couldn't stay the same.
I figured since the domain and range of f(x) belong to all real numbers, possibly f(x) = x and then inputting f(x+3) = x+ 3
then y = x+3
then y = x - 3 but I am not really sure if that's right :s
Mathematics news on Phys.org
True or False:
My ideas:
then y = x+3
You are given that ##f## has an inverse ##f^{-1}##. What happens when you solve the equation ##y=f(x+3)## for ##x##?
Good Day michellemich!
If you are not sure of your answer, try some composition: let your original function be f(x)and your questionable inverse function be g(x)
Evaluate (f of g) and (g of f). If they undo each other, they are inverses.
If you want to know if this is true for all invertible functions, it is simple enough to find a counterexample.
If, say, f(x)= 2x+ 3, then f(x)= 3x- 2, then f^{-1}(x)= (x+ 2)/3. f(x+3)= 3(x+ 3)- 2= 3x+ 7. The inverse of that function is (x- 7)/3. Is that equal to f^{-1}(x+ 3)= (x+3+ 2)/3= (x+ 5)/3?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
