Constant Acceleration Downwards
Gravity exerts a constant force on objects, resulting in an acceleration of approximately 9.8 m/s² downwards. When standing still on the ground, the forces acting on the body are balanced, meaning there is no net acceleration despite the gravitational force. Thus, while gravity is always present, it does not cause acceleration unless there is a lack of support, such as when jumping or falling. The confusion arises from the distinction between the force of gravity and the actual state of motion. Understanding this concept clarifies that an object at rest is not accelerating downwards while in contact with a surface.
nate99
I remember being taught that, due to gravity, we are always accelerating downwards. But how do you explain it?
Gravity is constant, and even if we are at rest, if I step on a scale I still get a weight of my mass X acceleration due to gravity. My forces vertically are balanced (me on the ground and the ground on me), therefore I have a constant velocity of no motion in the vertical direction.
But if I have no motion in the vertical direction then there is no change in velocity. I just stay at zero for velocity. So then how is my body ACCELERATING downwards? I completely understand that as soon as I jump or step off of a ledge and there is nothing to push up on me, my velocity will accelerate at 9.8 m/s2 in the down direction. But it's hard to understand how an object at rest is actually accelerating in the downward direction, unless I got my concepts mixed up, which often happens.
Thanks for the help!
You aren't accelerating downwards while standing on the ground.
Gravity applies a force to your body, which would accelerate you at approximately 9.8 m/s2 if it could.
I see, I guess I just learned it wrong in the past. Thanks for correcting me
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
