Viscous fluid flow in a manufacturing process
In a manufacturing process involving a highly viscous, non-Newtonian fluid, a problem known as "bridging" occurs when fluid in a vertical chute fails to flow down due to a cave-like structure forming at the bottom. This phenomenon prevents the fluid from continuing to move, despite being pushed horizontally by rotating screws. Bridging is commonly associated with granular materials in hoppers, suggesting that viscosity and chute diameter may influence its occurrence. Solutions may involve increasing the chute diameter or reducing fluid viscosity, potentially through heating. Understanding the mechanics of bridging can help address this issue in fluid dynamics.
czechman45
In work that I've been doing, we've come across an interesting problem. In a manufacturing process, a highly viscous, non-Newtonian fluid goes down a vertical chute and then gets pushed horizontally out the bottom by some rotating screws. Sometimes, the fluid gets pushed out the bottom, but the fluid in the chute doesn't continue to come down. The company that has this problem calls it 'bridging' where you essentially get a little cave at the bottom, the 'bridge' forming the roof and preventing the fluid from continuing to come down. I would like to know more about this. Does anyone know what this type of phenomena is called and where I might look to learn more about it?
Thank you!
Thank you!
I never heard of bridging happening with a viscous fluid, but is a common phenomenon in hopper feed with granular solids and powders. Look up bridging of granular material in hoppers.
Thinking about this I suspect the bridge formation is a function of viscosity and diameter. If you can influence either you can influence the probability that the bridge will form.
Can you increase the diameter or reduce the viscosity (maybe with heating)?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
