Electrical noise ( I mean sound waves )
Electrical noise in cables, transformers, and stations primarily arises from mechanical vibrations caused by electromagnetic forces, leading to audible sound waves like humming or buzzing. This phenomenon, often referred to as "mains hum," can be attributed to the interaction of alternating current with the physical components of electrical systems. Factors such as magnetic fields, resonance, and mechanical stress contribute to the generation of these sounds. To effectively search for more information on this topic, using terms like "electrical hum," "transformer noise," or "electromagnetic sound waves" may yield better results. Understanding the sources and mechanisms of electrical noise can aid in mitigating its impact in various applications.
planety_vuki
Hello physicsforums. What causes noise in electrical cables and/or transformers and/or electrical stations ? By noise I mean mechanical sound waves like bzzzzzzzz, not signal noise. And what is the proper way to search in google for this, I could not find a wikipedia article on this.
thanks !
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
