Thermodynamics - evaporator condenser
Increasing the flow of cooling water to the condenser in a multiple effect evaporator reduces the pressure in the condenser and the entire evaporator system. This occurs because the heat transfer area remains constant while the overall heat transfer coefficient increases due to a higher Reynolds number on the cold side. As a result, the cooling water temperature at the outlet decreases, which affects the pressure profile. The mass flow rate of condensate stays constant for a given flow of water and steam, indicating that thermodynamic changes are at play. Understanding the physical interactions rather than just relying on formulas is crucial for grasping these dynamics.
James MEng
Hello - fundamental thermo question which is puzzling me...
It concerns a multiple effect evaporator with condenser. Hot vapour is water, cooling medium is water.
My question stems from the following:
When the flow of cooling water to the condenser is increased, the pressure in the condenser (and thus the pressure profile of the entire evaporator) is reduced.
Here's how I understand it...
  • Heat transfer area of condenser remains constant
  • Overall heat transfer coefficient is increased slightly; given that the Reynolds number on cold side is increased
  • Cooling water temperature out is reduced (assuming heat load is constant and inlet temperature is the same)
How does this in turn lead to a reduction in evaporator pressure, please explain in basic terms (what's actually physically happening rather than just formulae! :thumbs:).
Thanks in advance for any replies
Edit: Also the mass flow rate of condensate will be the same for a given flow "in" of water and steam. Some thermodynamic activity is occurring here I just cannot work out what!
I'm wondering where it said that the outlet pressure from the condenser would be decreased. This doesn't seem reasonable to me.
