A spring is attached to the ceiling by a string with no weights
  • Thread starter Thread starter vstrimaitis
    Spring String
The discussion revolves around a spring system attached to the ceiling by a string, with specific measurements provided for the spring's dimensions and mass. Participants are seeking to determine the spring constant (k) and the period of oscillation for the system when released at a small angle. There is uncertainty regarding how to approach the problem without an attached weight and whether the same principles apply. Suggestions include visualizing the system through sketches and considering the spring as two separate springs if something is connected within it. Additionally, the weight of the spring itself and its effect on the stretching force at different points are important factors to consider in solving the problem.
vstrimaitis
1. A cylindrical string is made out of thin wire.
  • The distance between every loop of an unstretched spring is equal;
  • The radius of every loop of the spring is r = 4 cm;
  • The length of an unstretched spring is l = 20 cm;
  • The mass of the spring is m = 50 g;
The spring is hung on the ceiling by a non-elastic string which has a length of a = 10 cm. When the string is hanging, it has the length of l' = 25 cm.
2.
  • What is the constant of the spring (k)?
  • What is the period of this system, if the angle, at which it is released, is small?
3. I haven't really solved any problems when the weight is not attached on the end of the spring. Does it work the same way or not? If it does, I'll be able to find k. But I have no idea what to do with the period... Any help at all would be appreciated ^^
Please add a sketch of the system. It is hard to visualize this based on your post.
If something is connected to a point within the spring, you can split the spring in two pieces and consider them as two springs.
I hope this will clarify the problem at least a little bit.
Then you'll have to consider the weight of the spring. For a length x in the unstretched spring (where you need some definition of x), what is the mass below that point? What is the stretching force there? If the total spring has a constant of D, what can you say about each point, and finally the stretching of the whole spring?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
