Is Maximum Likelihood Estimation Valid with Limited Data?
Maximum Likelihood Estimation (MLE) is a method used to estimate parameters of a statistical model by maximizing the likelihood of observed data. The discussion emphasizes that while MLE can technically be calculated with limited data, having more samples increases the reliability of the estimates. A key point made is that MLE aims to find the model most likely to have produced the observed data, rather than minimizing the probability of errors. The analogy of coin flips illustrates that choosing a model that aligns with observed outcomes, even if extreme, is preferable to one that contradicts them. Understanding MLE involves recognizing that it focuses on maximizing the likelihood of the observed data rather than minimizing error probabilities.
senmeis
Hello,
I have a question to Maximum Likelihood Estimation. The typical form of MLE looks like this:
X = Hθ + W. W is gaussion with N(0, C).
θml = (HTC-1H)-1HTC-1X
I think θml can only be calculated after a lot of measurements are made, that is, there are plenty of samples of H and X. Or, it is impossible to get θml if only information about θ is known. Do I understand it correctly?
Senmeis
The typical form of MLE is that you have some random variable X that depends on a parameter \theta, and has a density p(x,\theta), then given some samples x_1,...,x_n of X, you find the value of \theta maximizing
\prod_{j=1}^{n} p(x_j, \theta)
or something to that effect (it might be different if your samples are dependent, or you have samples from different random variables etc.). You seem to have a very specific application of this to a Gaussian model. You can do the calculation with any number of samples, but the more samples you have the better odds you have that your MLE estimate is a good estimate of the real value of the parameter.
Likes 1 person
A measurement vector can be written as:
ø = Du + ε where ε is a zero mean gaussian random vector.
The MLE is Dml when P(ε) is maximum, but why maximum? I think the probability of ε shall be as small as possible. I know I must make a understanding mistake. Can anyone point it out?
Senmeis
In words, by picking D to maximize P(ε), you are saying 'My choice of D indicates that the events I just witnessed were not unusual in any way", whereas if you try to minimize P(ε), you are saying "My choice of D indicates the events I just witnessed will never happen again in the history of the universe".
To give a simple example, let's say I flip one hundred coins and all of them come up heads. I then ask you for a MLE of the probability that the coin lands on heads. If you want to maximize the probability that one hundred heads come up and notails comes up, you'll end up saying 'the coin has a probability of 1 of landing on heads' because if that is the case, then the probability that I get 100 heads in a row is 1. If you wanted to minimize the probability that the coin comes up heads 100 times in a row, you will tell me 'the coin has a probability of 0 of landing on heads.', and 100 heads coming up in a row will have a probability of 0. Which sounds more reasonable?
Senmeis
You want to find the model that most likely could have produced the data that you have. That is the goal of the MLE. If you have to chose between a model the is very unlikely to produce your data, and one that is likely to give those results, you pick the more likely one. If you have tossed a coin 50 times and got 50 heads, you would pick the model that the coin is rigged for heads, not the model that the coin is fair.
