Root Mean Square Speed Units Question
spockjones20
"At 273 K and 1.00x10^-2 atm, the density of a gas is 1.24x10^-5 g/cm^3.
A.) Find the Vrms for the gas molecules
B.) Find the molar mass and identify the gas (Choose from H2, He, H20, N2, O2, or CO2)"
Vrms = √(3RT/Mm)
pV = nRT
n = mass/Mm
pV = mass/Mm *RT
Mm = mass*RT/(pV)
Mm = ρRT/p
Vrms = √(3RT/(ρRT/p)) = √(3p/ρ)
So I have the solution up until this point, the main thing I am worried about is the units of my answer. I have pressure in atm, which is some form of Force/Area. I have density in g/cm^3. So pressure/density will be some form of (distance/time)^2, which of course is taken care of with the radical. The only thing I can not come up with is what exact units it will be in. Any help here would be greatly appreciated. Thanks in advance.
Likes Htet Htet Bo
A rule of thumb is that if you use SI units for every term in an expression, you can expect the answer to be in SI units. You can do a dimensional analysis to verify this as well. Converting atm to Pascals and g/cm^3 to Kg/m^3, should give you m/s for Vrms.
Ok, that makes sense. Thanks a lot!
Since ideal gas calculations can sometimes involve a mixture of different units, the following article gives values of R in several different unit combinations:
http://en.wikipedia.org/wiki/Gas_constant
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
